Skunk2 Coilover help!
Old Apr 8, 2013 | 11:12 PM
gnarlyj3rick's Avatar
Hit a road block installing these. Rear lower shock mount bolt area stripped, the frame part, so I managed to dremel off the built on nut on the other side to just throw in a longer bolt & nut.
Found some zinc/steel nut and bolts at Home Depot but the guy there told me he wouldn't recommend them for automotive.. Gonna check out Ace Hardware tomorrow morning.
Is there a certain strength I should look for in the bolts?
Old Apr 8, 2013 | 11:25 PM
TPColgett's Avatar
GO to a Honda dealer and get the real replacement bolts for like $5 and buy an appropriate metric tap for the hole, a whole kit can be like $35. That would be the right way to fix it. Grade 8, which is the highest grade available at a hardware store, MIGHT be OK. But Fixing it the right way will always be better than OK.
Old Apr 8, 2013 | 11:40 PM
Ah okay thought so, thanks. Check bernardi honda and saw the bolt. Gonna try to call my local honda dealer.
Old Apr 8, 2013 | 11:44 PM
TPColgett's Avatar
Yep, my receipt for my last two was $5.66 LOL SO worth it.
Old Apr 8, 2013 | 11:51 PM
Niiice. But I should be able to find a nut for it right?
Old Apr 8, 2013 | 11:55 PM
TPColgett's Avatar
should be a standard metric thread... Also my Pro C's were a bit thinner on bottom than the shock mount. I added a pair of washers per side to make sure there was no slop. Check the fitment and clearance on your while you are there! A Nylock or other locking nut may not be a bad idea either...
Kuturagi
Mar 29, 2012 04:25 AM
xorbe
Jun 14, 2008 04:00 PM
Spooling
Apr 20, 2008 10:45 AM
F-IT!!!
Dec 23, 2007 02:25 AM
F-IT!!!
Nov 18, 2007 12:38 PM
