310cc Injectors
Old Apr 25, 2013 | 12:41 PM
lightyear22's Avatar
310cc Injectors
What are my options for 310cc injectors. I have read that RDX Type S injectors will work but need slight modding. Is this correct? I am not looking to spend 3-400 on a set of injectors for my 08 Fit.
Thanks
Old Apr 25, 2013 | 01:21 PM
JazzITup85's Avatar
Originally Posted by lightyear22
What are my options for 310cc injectors. I have read that RSX Type S injectors will work but need slight modding. Is this correct? I am not looking to spend 3-400 on a set of injectors for my 08 Fit.
Thanks
fixed.
Old Apr 25, 2013 | 02:16 PM
k24afit's Avatar
I'm running rdx 410cc injectors they will fit just go to rywire.com and buy there adapters so it can be plug and play that's how I did
Old Apr 25, 2013 | 07:26 PM
I am about to install 10psi of boost off a KWSC. The 310cc are recommended, but would 410cc's work or be over kill? I am tuning with FlashPro and am mostly stock the rest of the way around.
Thanks
Old Apr 28, 2013 | 03:31 PM
lcq4blackstar's Avatar
Go with the 410's, I got them from club RSX Acura RDX Injectors w/ Clips (Set of 4) | RDX-INJ-COM | Fuel Injectors | Acura RSX,Honda Civic,K-Series Swaps,K-Series Engine | K Series Parts(company changed name). If you get the clips listed all you would need to do is unclip the plastic housing and switch it with the stock injector clips. Those of us using the 410's on the fit bought Scion TC clips (plug and play with the RDX injector). Here is a "how to" DIY: RDX Injector install - 8th Generation Honda Civic Forum
P/N
Order RDX injectors. Acura Part # 16450-RWC-A01
Order Scion TC clips: Toyota Part # 90980-11875
BTW I'm on 10psi Kraftwerks and the 410's now for a while. You will have room for more fuel with 410's and they have the best spray pattern.
Old Apr 29, 2013 | 12:51 PM
What are you using for your tune? I will be using a FlashPro. Will the base map for the KWSC 10psi with 410cc's on the FlashPro get me close enough to be drivable to the dyno, about 20 miles. Do you have a map? I am fairly stock, just want going to the grocery store to be fun. I was looking at these. http://jacksonracing.com/shop/fuel-i...uel-injectors/
Thanks
P/N
Old May 4, 2013 | 07:45 PM
What are you using for your tune? I will be using a FlashPro. Will the base map for the KWSC 10psi with 410cc's on the FlashPro get me close enough to be drivable to the dyno, about 20 miles. Do you have a map? I am fairly stock, just want going to the grocery store to be fun. I was looking at these. Honda 410cc Fuel Injectors | Jackson Racing
Thanks
Waiting on the flashpro to come in as well, IDK how you would use a "base map" from something else on the flashpro but your car will not turn over until you are able to scale the injectors fuel table back to the stock flow rate. I'm going to mess around with the flashpro but right now I'm on the AEM FIC. You could do the drive to the tuner with the stock injectors and stay in vacuum. Once you get there swap the injectors. If someone puts up a flashpro tune that you are able to get the car running on the 410's, you could get there out of boost as well.
Or you could always trailer it to the tuner.
If I can get some kind of map going on my own before taking it to get tuned I'll share it with you. To be honest, I haven't even installed the flashpro software on my computer yet. I don't want to get into it without the flashpro unit in hands...
Those injectors are the same as the ones I linked to before from clubRSX, make sure you get those clips! Much better than doing the swap with the TC clips and around the same price!
Old May 4, 2013 | 08:31 PM
The Kraftwerks/Hondata 10psi tune is loaded in the software. I am leaning towards getting used RC 310's that are part of the original kraftwerks/hondata tune. Get it up and running and see how close I am to maxing out or if the 310s will do enough. I am sure KW tuned to the safe side. I have been reading a thread where a L15 boosted more than 12, this guy was pushing close to 20 (I think) and left parts of his engine on the road. I can't remember the RC's that Kraftwerks were putting in the kit. SL2-0310, SL4-0310, SL9-0310?? I am still waiting on my flashpro (group buy). If you get a good tune on the 410s and would like to share that would be awesome. I have been looking all over for a FlashPro KWHB, 410cc tune with no luck. One e-tuner I talked to did think the 410's were a tad much for the little engine, but could tune it...
Old May 4, 2013 | 08:48 PM
Your talking about the hondata reflash for the stock ecu right? Well you shouldn't be running the stock injector with that reflash anyway, its meant for the bigger injectors. Why even buy the flashpro? Seems like a waste unless you plan do do more to the car than 10psi kit and exhaust... the reflash will do you fine. The flashpro is overkill for your goals IMO.
As for the 410's vs 310's, if you are buying new why not? You would be getting a better spray pattern with the 410's and who cares if your not using them to their max, its just extra headroom to tune with... go with the used ones but have them flow tested, its really not that expensive to just buy the ones you linked to. Peace of mind for a little more out of pocket IMO...
Old May 4, 2013 | 09:10 PM
I understand what you are saying, but to get the KW Reflash from Hondata is $399, for $200 more I can flash it myself and have room to expand from that tune or go in the other direction and step up with larger injectors, and other upgrades. This is a second hand KWSC unit and the seller didn't want to swap ECU's and get keys reprogrammed. I am completely stock right now. I plan to install the KWHB kit mid May, do the stock KWHB flash and go from there. I was hoping to be able to do that with the 410's with the KW flash change the injector size in the software and reflash. Run real fat during a datalog and adjust my numbers from there. But from what you are saying that would not be possible from the fit not able to start.
Old May 5, 2013 | 03:23 PM
That's not what I was saying, sorry for the confusion. I thought you were running the reflash already as you kept mentioning it. I was unaware that they have it available to flash onto the flashpro. You have the perfect plan right there! Get the flashpro, flash the KW 10psi reflash then scale the injectors back for the 410's. You won't even need to get the car running to scale them back if its like the FIC. All you would need to do is calculate the difference or it may be built into the software like it is for the FIC.
Old Jul 27, 2013 | 12:00 AM
Revjazz's Avatar
my question gsr turbo injector 310cc can use at l13a fuel rail ? anyone try it
Old Oct 11, 2013 | 08:55 AM
jdmkira's Avatar
The other day I was messing around with a set of rsx type s 310cc injectors and I they plugged right into my GD3's harness without modding... Don't the MDX's have the same clip pattern?
Spooling
49
Oct 11, 2015 10:19 PM
clanbuster
32
Feb 10, 2013 06:42 PM
TunaDaMan
Dec 30, 2010 06:38 AM
kevin6767
Apr 18, 2008 04:07 AM
kevin6767
Apr 7, 2008 12:52 PM
