replace washer fluid reservoir?
Old Jul 29, 2013 | 01:29 AM
bbb222's Avatar
Hi, any simple instructions to replace the washer fluid reservoir on a 2013 Fit? It started leaking after it got bumped in an accident.
Do I need to remove the headlight assembly and bumper to access the reservoir?
Old Jul 29, 2013 | 03:52 AM
loudbang's Avatar
Front bumper removal makes it a bunch easier but you MAY be able to do it from the back of the fender going in after removing the plastic fender liner. I don't think the headlight on that side.
The whole front comes off with a few Phillips head screws and pop out clips and if you have even basic skills it is easy to do.
Old Nov 6, 2013 | 10:49 PM
12vltfrk's Avatar
I had the same problem. I did need to drop the bumper. found out I broke the washer fluid motor and not the reservoir. I have a 09 fit, I do think its the same. if you need the reservoir I have one for sale, just PM me
Old Nov 7, 2013 | 05:13 AM
Black3sr's Avatar
Manual suggests removing bumper cover.
Looks kind of tough to remove those bolts through fender.
Noted Canadian Fits have a low fluid warning - hmmm
Old Jan 15, 2023 | 01:21 AM
Paula808's Avatar
Directions to replace washer reservoir?
Hi! My husband had a minor fender bender and the washer tank won’t hold fluid. I’m thinking it’s cracked. I bought a new one and want to install it but can’t find instructions online. What manual did you find the instructions on? Thanks!
Old Sep 18, 2025 | 12:07 PM
jainraje's Avatar
I have a 2019 Honda Fit Sport. I need to inspect the washer fluid reservoir, pump, tubes, etc. I come back from vacation and have a leak. The diagram is helpful. Any step by step instruction on how to replace the washer fluid reservoir? Removing liner from inside wheel well seems like the best approach.
toolboxjesse
Feb 26, 2017 03:04 PM
musky123
Feb 25, 2017 04:22 PM
michaelglasscook
Jan 16, 2017 12:14 PM
n9cv
Sep 23, 2014 11:40 PM
xander
Feb 2, 2009 01:50 PM
