what's the size of bolt to remove rear drum?
Old Aug 1, 2013 | 03:27 PM
jimmyparky's Avatar
My '07 fit sport's rear drum is squeaking everytime when I release the break. It's coming from the brake shoe sliding on the back frame. I tried silicon lubricant before because I didn't have any grease at the time, but now I'm trying to grease it and can't seem to release the drum cover. I tried using 8x1.25 bolt but that was too big and it wouldn't even stay threaded and 6x1 was too small.
So what's your recommendation?
Old Aug 1, 2013 | 04:06 PM
Dean's Avatar
that's odd because in both my Fit/Jazz Shop guides it's showing (2)8x1.25mm?
Old Aug 1, 2013 | 04:29 PM
jimmyparky's Avatar
That's what I thought, but even looking at the hole seems small for 8x1.25 and wouldn't catch a thread at all.
Old Aug 1, 2013 | 07:52 PM
Hootie's Avatar
I tagged mine with a hammer a few times to break the surface rust off and removed my drums.
Old Aug 2, 2013 | 01:43 AM
loudbang's Avatar
Try the hit with a hammer trick and wiggle them off by hand. If they doen't come right off you may need to adjust the shoes inward with a manual adjuster spoon.
Old Oct 7, 2014 | 12:21 AM
jimmyparky's Avatar
I still haven't removed the drum. The brakes are ok, it's just the mechanism that pushes the brake shoes is rubbing against the back board(metal to metal) and is making the sound everytime I let go of the brakes which is totally annoying.
I know the brake shoes are not rubbing because I can turn the drum. It's just stuck really good.
Anyone used a bolt to remove the drum? Which bolt did you use?
justus
Feb 28, 2024 06:21 PM
fitowner10
Oct 18, 2019 12:06 AM
lausy
Aug 8, 2017 12:35 AM
Kurse
Nov 8, 2009 12:26 PM
charwai
Feb 27, 2008 03:05 AM
