HondaCare: Coverage Question
Old Aug 19, 2013 | 02:20 PM
flyingby's Avatar
I recently purchased a used 2009 Honda Fit with 95k miles. It has a 100k HondaCare warranty on it that I am transferring. At time of purchase the independent mechanic I took it to stated the serpentine belt and tensioner needed to be replaced. The seller paid so I gave little thought to possible warranty coverage/issues.
Fast forward 1,000 miles and I have a sound originating from the engine. *Summarized on my other post*. I think it is related to the replaced belt/tensioner. My question is, will HondaCare cover anything if the noise is found to be related? What if it is not related? Did I just void the warranty?
I can take the car back to the original mechanic but, if the warranty is still good, I don't want to have even more work done outside of the dealership.
Old Aug 19, 2013 | 02:27 PM
is that a factory piece? if so honda might still help you.
if it is an aftermarket part, then no. you will need to go back to your mechanic.
Old Aug 19, 2013 | 02:31 PM
flyingby's Avatar
Honda Factory Piece
Old Aug 19, 2013 | 02:34 PM
i would definitely check with honda if that's the case.
Old Aug 20, 2013 | 03:21 PM
Doug Just Doug's Avatar
The extra warranty probably doesn't need to come into play. If an OE Honda replacement part was installed, it's warranted separately for failure. If it was the independent mechanic's fault, you'd have to take it up with him.
Old Aug 20, 2013 | 03:42 PM
the car has over 95K miles... does honda's standard warranty cover cars with 95K miles?
Old Aug 20, 2013 | 05:40 PM
flash75's Avatar
"does honda's standard warranty cover cars with 95K miles?"
No. But genuine Honda parts should have a warranty, I don't know how long they are warranted, maybe a year.
Clifton
__________________
Old Aug 20, 2013 | 05:51 PM
DavefromCA's Avatar
They should be warrantied for 12k or a year. You should take it back to the original mechanic, or you could just take it to honda and play dumb.....but really it should go back to the guy who did the work. First thing is first however you need to be sure it is the same problem.
Old Aug 21, 2013 | 10:48 AM
Taken from American Honda's website: "Replacement Parts Limited Warranty—Honda Genuine Parts are covered for 1 year. The warranty coverage for replacement parts purchased from and installed by a Honda dealer includes parts replacement and labor."
Owner Resources - Official Honda Web Site
NEW2FIT
Jan 1, 2023 06:20 PM
silverrose12
Jun 10, 2019 11:21 AM
JonBoz5099
Mar 26, 2015 11:36 AM
Blissx21
Mar 14, 2012 09:58 PM
moolman
Dec 3, 2011 12:18 AM
