Any Suggestions on an Intake?
Old Dec 4, 2013 | 12:47 AM
Jmconiglio's Avatar
Picked up a PMM 2012 Fit Sport-Navi a while ago and was thinking about throwing an intake on it. Any suggestions? Brands? Prices? Performance?
Old Dec 4, 2013 | 02:45 AM
xxryu139xx's Avatar
prm best bang for ur buck =)
performance wise they will all net u the same = 0
Old Mar 28, 2021 | 10:57 AM
NWCH's Avatar
I'm using the AEM. I love it.
Old Mar 28, 2021 | 06:14 PM
elkaku's Avatar
If anyone is interested in these.... Hit me up...
Used to fit a larger TB
I recommend any of these to use on a stock engine
GMB6A CiViC Si 06-11 61mm
GMB1A Accord-TSX 04-05 61mm
GMB2A Odyssey 2006 2.4L 61mm
GMA0A CR-V 2005-06 61mm
Old Mar 29, 2021 | 11:06 AM
NWCH's Avatar
Complete waste of money. The Fit doesn't need a larger throttle body. lol
Old Mar 29, 2021 | 01:56 PM
elkaku's Avatar
Come on dude before roasting or doing those kind of comments, you could give an explanation on why they doesn't... There is no reason at all for the negative comments....
If its not necessary... Then why are there companies making them and also modifying OEM TB's and manufacturing IM's with larger TB openings....
If you dont like it dont buy it but there's no reason to trash a post...
Old Mar 30, 2021 | 09:35 AM
mmm def's Avatar
I'm using HPS-not that expensive, sounds good and improves throttle response a bit. Was looking into K&N but the install seemed a bit more complicated with a coolant hose change.
Old Mar 30, 2021 | 12:32 PM
steve37's Avatar
^^^ I've had the HPS short air intake also for two years now. I like it a lot.
Opened up a ton of space....easy to drop in a 51R battery...and the engine compartment looks so much less cluttered.
Old Mar 31, 2021 | 10:39 AM
oldyeller's Avatar
I have an HPS intake on my Fit as well. Slight increase in throttle response but you can hear the intake a lot more. Since an intake isn't going to really increase power that much on a Fit I just went with whatever's cheapest (HPS). And because the HPS intake is shorter than the K&N style ones where they route infront of the battery it makes it a lot easier to access anything under or behind the battery without removing the intake. Just bear in mind any time you pop the hood you'll have insufferable fuckboys say "NiCe HoT aIr InTaKe BrO" without fail.
Old Aug 21, 2021 | 12:29 AM
Secretivecj's Avatar
Have the Injen. Love it.
fitisno
May 4, 2011 03:20 PM
iLUVYOURGE8
Jun 20, 2009 01:47 PM
OneStopCustoms
20
Dec 16, 2007 07:32 PM
samwell
Jun 18, 2007 11:13 PM
kurtdesch
May 3, 2006 11:28 PM
