Part number for gearshift light bulb?
Hello, 2008 Fit Sport AT. The bulb in my shift lever console has failed. I would rather have a part number rather than disassembling the console to take it off and bringing it to the dealer parts counter. This diagram shows the bulb (#1) but does not list a part number. Any insight?
Honda Automotive Parts
35505-S30-003 (The sixth digit is the letter "ess" not the number five) Cost was $3.11.
The actual replacement process is moderately involved. You have to loosen the center console by removing two screws at the rear and pulling up the trim around the e-brake handle. The shift lever knob must also be removed (two screws) to allow the trim to be pulled up. Release four clips that secure the silver escutcheon trim around the shift lever and the bulb socket is then exposed.
