Part number for gearshift light bulb?
Old Dec 6, 2013 | 12:35 PM
kbh's Avatar
kbh
Hello, 2008 Fit Sport AT. The bulb in my shift lever console has failed. I would rather have a part number rather than disassembling the console to take it off and bringing it to the dealer parts counter. This diagram shows the bulb (#1) but does not list a part number. Any insight?
Honda Automotive Parts
Old Dec 7, 2013 | 07:25 AM
Carbuff2's Avatar
The parts list below the diagram you posted shows the part #
37700-SAA-984
Old Dec 7, 2013 | 03:00 PM
kbh's Avatar
kbh
37700-SAA-984
Actually that is for the entire harness assembly. No one would pay $34.79 for a bulb. I ended up going to the dealer parts counter. The bulb is a standard Honda press-in bulb that I have used in my Acura and Odyssey as well.
35505-S30-003 (The sixth digit is the letter "ess" not the number five) Cost was $3.11.
The actual replacement process is moderately involved. You have to loosen the center console by removing two screws at the rear and pulling up the trim around the e-brake handle. The shift lever knob must also be removed (two screws) to allow the trim to be pulled up. Release four clips that secure the silver escutcheon trim around the shift lever and the bulb socket is then exposed.
wyndotte1947
Jul 17, 2024 05:00 PM
Hombre de senoras
May 28, 2018 05:08 PM
cjecpa
Feb 17, 2013 10:15 PM
Ron's Auto Care
Jun 24, 2012 05:21 PM
drock305
Feb 9, 2010 08:06 PM
