whining sound from front of engine
Old Dec 22, 2013 | 05:24 PM
55-1218's Avatar
2009 Fit Sport 5sp all stock with 71,000+ miles. Makes a whining sound like an old Chevy power steering pump gone bad. (Yes, I know Fit steering is electric) Same noise at idle with trans in neutral. Increases with RPMs. No change with radio off, ac on/off, or alternator under load from headlights/flashers. Can't feel wobble in any pulleys, but that maybe because belt is still tight. Searched other threads, no plausible answers found. Suggestions? Thank you.
Old Dec 23, 2013 | 04:22 AM
Goobers's Avatar
Maybe you're hearing the cam chain?
I know I can hear mine once in a while.
Old Dec 23, 2013 | 10:38 AM
palos's Avatar
Use a dowel rod, mechanic's stethoscope, etc. and listen for noise from the water pump, compressor and belt tensioner.
Old Dec 23, 2013 | 11:41 AM
55-1218's Avatar
Thanks. I'll try that.
Old Dec 23, 2013 | 02:28 PM
55-1218's Avatar
Was unable to determine on my own. Dealer said it is idler/tensioner.
Old Dec 24, 2013 | 02:52 PM
55-1218's Avatar
Was indeed the idler/tensioner pulley. VERY easy to take off and re-install. Bought a replacement bearing for under $4. Paid a guy at machine shop $5 to push out the old one and press in the new one. If you need further details, let me know. I'll be glad to talk you through the process. Thanks to all the posts and replies from members. I love my Fit!
Old Feb 18, 2018 | 12:29 PM
tbonemeli's Avatar
Idler pulley / tensioner noise
Hi all, I just started getting this noise on my 2007 Fit with ~185K miles. Took to shop and they couldn't hear a significant noise and didn't know for sure, though suspected a bearing. After doing some youtubing, this is the noise and it sounds like it coudl be ideler pulley / tensioner.
My question is given that this noise just started a day ago, is it safe to drive my car ~200 miles back home from where I am or will I risk a breakdown on the freeway?
Thanks all!
Old Feb 19, 2018 | 08:26 AM
Carbuff2's Avatar
We had a similar noise (at first, only when cold) and it turned out to be the A/C compressor clutch.
See if you agree:
If it IS the A/C clutch, yes you can drive it home. When ours finally failed the A/C wouldn't work is all. (But it was quiet, LOL)
Looks like an issue with Blaze Orange Fits!
Old Jan 26, 2019 | 08:35 PM
narianu's Avatar
Would you please give more details on how you replaced the bearing? I'm looking at the OEM parts diagram and I don't see a separate bearing assembly, just the whole pulley and bearing cap. The tensioner pulley in my 2009 Fit with 90K miles seems to have started whining after driving it in -5 degree (F) weather.
Old Jan 26, 2019 | 11:56 PM
JerrySFL's Avatar
NSK 80SPF0310DDU AC Drive Belt Idler Pulley $26 on Amazon, they also have a Dayco for less but I never had good luck with Dayco.
Old Jun 13, 2019 | 11:36 AM
Tha Dragon's Avatar
Talking
Hi there isn't there any chance you have a video or pictures to walk me through?
Thanks in advance
RandomKoko
Jun 29, 2017 09:10 AM
doctor J
Sep 28, 2016 03:09 AM
SquirrelBoy
Sep 23, 2016 03:33 PM
blazej
Feb 24, 2016 07:37 PM
arealitystudios
Nov 26, 2012 04:49 PM
