PMLIT License Plate Lights
Old Mar 16, 2014 | 06:56 PM
fawbusha's Avatar
I found these browsing around, they look pretty sweet. I'll probably pick up a set next paycheck. Here's the info:
Website:
PMLIT 02-13 Honda Fit GD GE Frozen White LED License Plate Light Bulbs Kit
Details
Looking for the perfect visual upgrade for your vehicle? New, PMLIT® High Bright LED OEM Replacement License Plate Lights will look absolutely terrific in your car. Increased visibility of your interior makes these the obvious choice for a quick and easy visual enhancement, making you stand out from the crowd and get you closer to the show-car you always wanted.
Description
Precision engineered, these Frozen White License Plate Lights are designed to perform and outperform any competition. The PMLIT® LED License Plate Lights replace your existing License Plate light Halogen Bulbs to instantly bring your vehicle's appearance to new life. LED License Plate Lights are the most cost effective way to improve the appearance of your car and give you the styling you deserve. Each set is constructed of the highest quality components. Our LED License Plate Lights are the newest style of interior lighting available on the market. These LED License Plate Lights are your way to get that racing look. These LED License Plate Lights are a technological breakthrough in manufacturing. The result is a more powerful LED License Plate Lights installed directly instead of the existing factory halogen bulb.
Available in PMLIT® Color:Frozen White
Note: if for any reason you decide over time that you want to remove the LED kit, the process can be reversed.
PMLIT® License Plate Light Bulb Package Contents:
-One (1) Packaging Box
-Two (2) 9W LED License Plate Lights Housings
-Two (2) LED Resistors
-Two (2) LED Capacitors (IF NECESSARY)
-One (1) Brochure/Installation Manual
Old Mar 16, 2014 | 09:13 PM
klaw091's Avatar
I would just buy leds and swap out the stock bulbs.
2013 Honda Fit License Plate LED Lights | LED Replacement Bulbs for Cars | 12v | Super Bright LEDs
It will get the job done for a lot less $$$. That is what I did
Old Mar 16, 2014 | 09:16 PM
fawbusha's Avatar
That's a good point klaw091 but I've already broken one of the housings so this looks like a good route to go
Old Mar 16, 2014 | 09:21 PM
klaw091's Avatar
Lens:
http://www.ebay.com/itm/HONDA-OEM-34101S60013-License-Lamps-Rear-Lens-/161086337845?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AHonda%7CModel%3AFit&hash=item25817e7335&vxp=mtr
Gasket:
http://www.ebay.com/itm/HONDA-OEM-34103S60003-License-Lamps-Rear-Lens-Gasket-/141213678967?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AHonda%7CModel%3AFit&hash=item20e0fdbd77&vxp=mtr
I broke one of the tabs removing the lens as well. I just bought the lens. I didnt realize it did not come with the gasket until I received it. Figure...LEDS are less susceptible to the environment compared to the halogen bulbs so I left it as is.
klaw091's Avatar
You can probably get the parts locally too if you're in a rush.
Old Mar 16, 2014 | 09:38 PM
fawbusha's Avatar
Thanks for the part numbers bro
dancingsun
67
Jan 19, 2015 05:55 PM
JDM-Taffeta-S
Nov 20, 2008 05:39 PM
Halcyon
May 7, 2008 01:46 AM
BlueCell
Texas Community
Feb 21, 2008 11:33 PM
TomiGunz
Sep 20, 2006 07:05 PM
