Corossion on battery
Old Aug 28, 2006 | 04:43 PM
hqly's Avatar
I did the idle learn procedure and a week later.. i notice that the nut and bolts for the negative connection of the battery is turning white.. i guess i must have wipe something off during the process.. how can i clean it so it doesn;t turn white and powdery looking?
Old Aug 28, 2006 | 04:59 PM
Fray Adjacent's Avatar
Senior Member
Mix some baking soda in some water, and clean it with a tooth brush and the mixture.
Old Aug 28, 2006 | 05:48 PM
ichthus's Avatar
That sounds like too much work
Easiest way to clean a battery? Can of Coke. No kidding, just grab some Classic Coca-Cola, open, and pour. Cleans the battery connections quicker than you'd think possible. And there's no mixing and scrubbing or brushing to be done.
Old Aug 28, 2006 | 06:06 PM
wyy183's Avatar
When you get them clean, coat them with vaseline (I just use a Q-tip, and rub it all over to "seal" it against oxidation.)
Old Aug 28, 2006 | 08:51 PM
Joe_Schmoe's Avatar
Then you have a sticky mess of coke to clean up.
Old Aug 28, 2006 | 09:05 PM
ichthus's Avatar
it doesn't take that much, and a paper towel will work just fine. Literally, the stuff disolves on contact.
erichyung
Mar 16, 2026 04:11 PM
ChuckDustin
Mar 29, 2019 09:11 PM
Remco
May 4, 2005 11:16 AM
Remco
piclistguy@yahoo.com
