DW-1 replacement with AMSOIL or REDLINE synthetic A.T.F. : Anyone using one of these
Old May 17, 2014 | 11:09 PM
Odie's Avatar
Question DW-1 replacement with AMSOIL or REDLINE synthetic A.T.F. : Anyone using one of these
for their FIT ? If so , any improvement or problem ? AMSOIL Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid and http://www.redlineoil.com/product.aspx?pid=115&pcid=7 . Plan to get a drain and fill around 35,000 miles .
Old May 18, 2014 | 09:36 AM
Carbuff2's Avatar
No comment except to point out that your second link is for RL Manual tranny lube. DO NOT use that in an automatic!
Old May 18, 2014 | 10:35 AM
Odie's Avatar
Thanks for pointing that out . Just corrected it in the original post . It's REDLINE D6 A.T.F..
Old Apr 29, 2016 | 09:35 PM
Mainia's Avatar
Originally Posted by Odie
for their FIT ? If so , any improvement or problem ? AMSOIL Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid and Red Line Synthetic Oil - Gear Oil for Manual Transmissions - D6 ATF . Plan to get a drain and fill around 35,000 miles .
Yes, 2009 Fit Sport ATF pumper. Switched over at 22,000 miles. Now at 55,000. 3 drain and fills with Redline D6 the last 3 qts a mix of Lightweight Racing and regular Racing Redline ATF. D6 still has too much slip agent for my liking. At 50,000 I did the same 2 dump and fills with one more qt regular racing added at the fill of the first dump first dump too get a tad more less slip. Zero problems, I am hard on the trans, so I don't want slippy shifts.
Added note, my car is stored because of the airbag recall and I ran it around the block to de rust the rotors and if you let the car sit, the clutch plates REALLY soaks up the racing ATF. Very precise hard shifts 30% more then what I had when I was driving it daily.
I am using a loaner from Honda 2015 CVT. I really like this CVT.
I am thinking of buying one but the CVT reliability worries me.
Wafulz
Apr 30, 2016 03:27 PM
JimFit61
Aug 26, 2015 05:10 PM
spreadhead
May 7, 2014 11:57 AM
J3SS13
May 15, 2012 09:12 AM
Wiggles
May 27, 2007 08:43 PM
