Are you still on your OEM battery?
Old May 30, 2014 | 03:00 PM
Spacecoast's Avatar
2009 FIt...early in the year manufacture/in-service...battery still seems ok. Anyone else with a 2009 OEM battery?
EDIT....in-service date is October 2008 (bought it used in 2009).
Old May 30, 2014 | 03:03 PM
avocado123's Avatar
FALCON PUNCH!!
I replaced my battery in January. Bought the car in March 2008. Almost 6 years on the OEM battery, couldn't really complain when it finally died, hah.
Old May 30, 2014 | 06:16 PM
Spacecoast's Avatar
Same here...I'm happy with the OEM battery...still ok. Did yours give any warning, or did it just suddenly die?
Old May 30, 2014 | 09:58 PM
avocado123's Avatar
FALCON PUNCH!!
I knew a couple months before it died. I could hear that it took just an extra moment to crank up.
Old May 31, 2014 | 01:45 AM
n9cv's Avatar
I also have an 09 with the original battery. We had a couple of -20 F days last winter and it still started OK.
Old May 31, 2014 | 09:52 AM
Steve244's Avatar
I replaced mine in December. It was cranking a little more slowly.
January it sat out all night in 13F weather (great atlanta icepocolypse). Next morning it started without a whimper. Not that this is any justification but I would have felt silly trying to prolong the old battery's use if it had crapped out.
$90 with trade-in at NAPA for a 151R.
Old May 31, 2014 | 11:46 AM
sooznd's Avatar
Yes- I have a 2010 with about 33K miles. I recently had it to the dealer for transmission fluid & oil change. They said my battery tested poor & recommended replacing. I have had no problems with it starting, so will wait until I do to replace.
Anyone know of a good inexpensive source for the battery? My dealer's quoted price was less than AutoZone. Hope my NAPA will give me the same deal as Steve/
Old May 31, 2014 | 02:24 PM
Steve244's Avatar
Check napa auto parts online for your zip. They're currently charging $92 with trade where I live. No special deal. I don't think they'll install it out in the parking lot like some parts stores will so be willing to yank it out yourself. You can return the old battery at a later time, just pay $15 more and get a $15 refund when you turn it in.
Old May 31, 2014 | 04:36 PM
Codger01's Avatar
Still on the OEM battery, with 97K on the clock. Does sometimes crank a little more before firing up the engine, not slower but more of a "chug chug chug vroom" instead of a "chug vroom" on start up.
Old May 31, 2014 | 05:37 PM
Steve244's Avatar
I think that has to do with the volatility of the fuel. Summer blend has longer molecular chains and doesn't evaporate as readily. It requires more cranks to reach a combustible mix.
Old May 31, 2014 | 10:51 PM
Cat's Avatar
Cat
Still on the original battery in my 2007 Honda Fit - with 40,800 miles!
Old Jun 1, 2014 | 01:16 AM
nukeme70's Avatar
I still have my original battery. Turned 100k a couple weeks ago. Bought the car new in Aug/Sep 2008. The last 3 times I've taken it to the dealer for an oil change, they've told me the battery fails their testing. I figure as long as it turns the engine, that's not failing. It has the same symptoms that Codger01 described - takes a couple extra chugs to turn over, but still does.
I'm also on the original wipers (though the rear is torn...).
Old Jun 1, 2014 | 08:58 AM
Spacecoast's Avatar
Thanks for the replies...good to know that battery life can be quite good. In replacing the battery, be sure that the new battery has a current date. I called my local NAPA store just to check to see if they had a 151R and they did....but its been sitting on the shelf for over a year. If its more than one of two months old, I wouldn't purchase.
Old Jun 1, 2014 | 09:30 AM
Steve244's Avatar
Good point, mine came with a current date stamp (it's usually just a letter equivalent to the month (Jan = A, Feb = b, and so on) and the year 14).
I'd be reluctant to take one more than 60 days old. They lose charge on the shelf and sulfate, losing capacity. As long as they are kept charged (the normal condition in your car) they don't sulfate.
Side note: the NAPA battery I got was made in Korea. I wonder if they added acid over here?
Old Jun 1, 2014 | 09:36 AM
Steve244's Avatar
Thanks for reminding me, they're about $3.50 each from Honda (refills).
Old Jun 1, 2014 | 12:36 PM
Texas Coyote's Avatar
My battery went bad last month.. I bought my car in July of 2006.. That is a little over seven and one half years I got out of it. I was hoping to get eight years out of it.. I'm sad that it didn't last longer....
Old Jun 2, 2014 | 01:01 PM
Spacecoast's Avatar
Yea, its a shame not to get a good life-span out of a small battery...I feel for ya, LOL.
Old Jun 2, 2014 | 02:05 PM
blazej's Avatar
Yes. I have an 09 (bought in April of 09) with 95K miles and the OEM battery. I wonder when it will go.
Interestingly enough, the battery died the day I bought the car. We had it in a parking garage, and then didn't use it for a week and the battery died (I guess it was on the boat/ dealer lot for a while). I drove it for about 2 hours and never had the problem again.
Old Jun 2, 2014 | 06:26 PM
SR45's Avatar
Hot florida sun....
2010 Accord (5 months old), battery was replaced free by dealer when they discovered it was failing. Tech said the battery was too small for size of vehicle. Higher cranking power battery installed
2011 Civic, also about 6 months old and battery was failing, but replaced free by dealer.
2011 Fit, 17 months old, no issues
2013 Civic in family, and all is well, 18 months
Old Jun 2, 2014 | 07:43 PM
Waiz's Avatar
Avid FitFreak Poster
2010, 34k miles with an in-service date of November 2010
Still on OEM battery
