2007 Fit Auto getting poor mileage (20 MPG)
Old Jun 9, 2014 | 04:25 PM
Zajora's Avatar
Here is my calculated mileage for my last 18 fillups:
These were calculated by doing the odometer difference and the fillup amount, so they should be pretty accurate, I think.
Even though this is almost entirely city driving, I still think something's up. I think most estimates of the city MPG for the 2007 Honda fit are around 27-33 MPG, while the absolute highest I've gotten is 24 MPG, with an average of about 20.
Info:
Odometer Reading: ~180,000 km (111,847 mi)
Tire Air Pressure: ~35 PSI
Oil Changed
Engine Air Filter Changed
Gentle acceleration (never above 3000 RPM)
Any ideas what could be causing this? I read on here about flushing the fuel injectors, but it seems like a lot of people have also said that fuel injector flushing/cleaning is basically just a scam for the dealership to get more money.
Old Jun 11, 2014 | 09:50 AM
Fit Charlie's Avatar
Wow, that's harsh. If there's something that far wrong with the car you'd probably know it without looking at the pump numbers. Do you have a lot of lights, construction or something like that in your area to leave your car idling a lot?
Old Jun 11, 2014 | 04:33 PM
Zajora's Avatar
Not more than any other city, I think. I also should mention I pretty rarely use the AC.
What do you think I would notice if there was something wrong? Sometimes I feel like it doesn't have enough power, but then again, it's a Fit, so..
Old Jun 11, 2014 | 07:39 PM
ikutoisahobo's Avatar
When you mention the lack of power and bad MPG it makes me think of coil packs every time. It could be coil packs.
Old Jan 22, 2015 | 11:06 PM
gd3~fit's Avatar
Old Jan 22, 2015 | 11:20 PM
john21031's Avatar
The cause of poor fuel economy could be just about anything.
To do proper diagnosis, you need to understand how major systems contribute to fuel economy.
Things that need to be checked:
EGR system performance
MAP, MAF, Intake temp/coolant temp sensors,
Coils, Valve clearance,
Catalytic and O2 sensors' functioning;
Brakes, bearing, alignment; compression, timing, fuel injectors; presence of sludge in the engine, making sure no trouble codes are pending or have been present recently.
Also your driving style needs to be checked/compared to other people/other cars.
Old Jan 23, 2015 | 10:07 AM
Gordon Smith's Avatar
Zajora: Nice record keeping. I'd start with 4 shiny new NGK spark plugs. And use Chevron gas for awhile. Those two seemingly minor adjustments might just surprise you.
Old Aug 23, 2022 | 04:09 PM
demouser's Avatar
I was going to post about poor fuel economy, but I see mine is fairly normal.
2010 Fit Sport Automatic, 112,000 miles, runs great, all maintenance done. Never had the check engine light on.
28-29 MPG around town, 32 on the highway. 26-27 in winter.
I do have to drive somewhat aggressively due to Chicago area traffic. 80 mph is normal on the expressways around here even in a 55.
Became concerned after a neighbor with a 3rd gen Fit gets mid-30's around town and our '16 Civic gets 35 in town and over 42 on the highway.
TCroly
Apr 17, 2014 05:11 PM
TheRegulator666
Aug 7, 2012 06:08 AM
Chairman Kaga
Aug 7, 2011 11:39 PM
txmatt
Mar 28, 2009 01:12 AM
Giggles
May 15, 2008 06:31 PM
