Windshieldwiper noise
Old Sep 2, 2006 | 05:42 PM
coldstorage5's Avatar
Hello,
My wipers make a lot of noise, every time they wipe the window, it makes an annoying rubbing noise.
Does anyone else have this problem?
Any Suggestions??
Thanx
Old Sep 2, 2006 | 05:47 PM
spreadhead's Avatar
Relace your blades with Anco.
Old Sep 2, 2006 | 10:00 PM
DewaltDakota's Avatar
I went with Teflon blades... MUCH quieter, and a cleaner sweep.
Old Sep 3, 2006 | 01:27 AM
StormSilverGD3's Avatar
Teflon, eh? Where'd you get those? That's something I'd like to look into.
I've used silicone blades before that lasted me 3 years!! They were SUPER quiet. You couldn't hear them swipe the window at all.
Old Sep 10, 2006 | 08:01 PM
Spule 4's Avatar
I got a Bosch 24" for the drivers side, 16" would be too long (would hit windshield trim) for the passenger (this wiper's mounting point is off centre anyhow, check and you will see) so it will be 15" on the passenger side, which is about 1/2" shorter on the end toward the driver. The local Napa jobber did not have this in stock, so I ordered it.
They (Napa) were surprised that I wished to replace them.
I have used Robert Bosch wipers for years without problems. From reading, PIAA would be good too (forum sponsor Tire Rack sells these), but no local dealer. Anco are also fine, they are the OEM maker for US Toyotas if memory serves.
Old Sep 10, 2006 | 08:08 PM
Trico makes the teflon blades. I bought mine at the local Advance Auto Parts. It takes a 24" and a 16"... though I think a 15" would fit better. Even Honda seems to know that the 16" is too big, since they specifically notched the window trim for the blade to sweep across it.
Old Sep 11, 2006 | 02:54 AM
sy11580's Avatar
I had a same problem..........the noise is killing me. so what is the perfect size 24" driver 15" passenger, right?
Old Sep 11, 2006 | 07:54 AM
Chingwa's Avatar
Hmm, the one occasion I've used mine so far, I could hear my wipers at all... I guess I should wait until we get a really good rain here to see how loud they are.
Old Sep 11, 2006 | 08:38 AM
FitSport's Avatar
If its a light mist they will make the rubbing noise. A couple of things you can try is to 1 clean the windshield with a razor blade and foam style window cleaner. It may still have stuff on it from manufacturing. Also clean the rubber blades with a cloth impregnated with rubbing alcohol. This may alleviate your problems...
Old Sep 11, 2006 | 04:21 PM
I would go over it with a clay bar, instead of a razor blade, as the clay will lift out any debris from the tiny imperfections in your windshield.
Old Sep 11, 2006 | 04:32 PM
glhboy's Avatar
Mine do the same thing, when I go back for an oil change, I'll ask that they replace them under warranty.
Old Sep 11, 2006 | 04:35 PM
Spule 4's Avatar
Just put the Bosch on, million times better.
Old Sep 11, 2006 | 04:36 PM
glhboy's Avatar
cause I'm a cheap ass and I don't want to buy them.
Old Sep 12, 2006 | 12:44 PM
gavinl's Avatar
Try Silicone wiper blades, they worked well for my Subaru. Some have integrated spoiler on the blade frame
I'll put them some on our FIT once it arrives end Oct
Can be found on Ebay
Old Sep 12, 2006 | 07:23 PM
switchbrdopr's Avatar
I've had the same problem since I bought my Fit in April. The dealer has waxed my windshield, replaced the blades, replaced the wiper motor, and consulted with a "glass guy" and nothing has helped so far. I took my Fit in about two weeks ago, and I am waiting for my dealer to contact Honda to see what they suggest. The wipers work fine, but the noise is extremely annoying. Please let me know if you get yours fixed so I can tell my dealer what to do.
Old Sep 15, 2006 | 03:05 PM
KenClunk's Avatar
I am having the same problem. It is only happening on the passenger blade. I am going to try the cleaning, Wax, and alcohol tomorrow. I may have to upgrade the blades. When I replace the blades I usually upgrade but I would like to use the factory blades as long as possible. After all I did pay for them.
Old Sep 15, 2006 | 08:53 PM
jrlnc's Avatar
I got some Ancos today . . .
I went to Autozone and said I wanted new wipers on my Fit. Their listing had some by Botsch but they were not in stock. So I told the guy helping me it needed a 24" and 15".
He recommended Ancos which they had a promotion on. $16.98 before tax and then had a mail-in rebate for a $10 gift card. What a deal. He even put them on for me. While he was installing them he said he was a Honda fan and really liked the Fit and the way it looked.
These Ancos look more like regular wiper blades. I always thought the original ones were too fat and blocky.
Old Sep 15, 2006 | 09:26 PM
sy11580's Avatar
I want to know does any aftermarket brand produce same style Windshieldwiper as OEM???
Old Sep 16, 2006 | 09:40 PM
edstroyer's Avatar
I had a noise problem with my wiper blades and solved it by sliding the wiper blade out and reversing it.
On the wiper blades you'll see the words HONDA in braille, My wiper would "hop" and make a staggered rubbing noise right at the spot on the wiper blade where it said HONDA. The noise/hop would only occur when the blade was going up.
After reversing the blade, there is no more noise. Hope this helps...
Old Sep 16, 2006 | 11:00 PM
I'm going to try your trick and see if it works for me also.
