Windshieldwiper noise
Old Sep 22, 2006 | 09:24 AM
jonniewishbone's Avatar
I also have had the problem since the first day. Only the passenger side. In a mist, medium rain, or downpour I get the same "loud" annoying noise. I don't use my wipers now until the last possible moment. Had the window and wipers cleaned by the dealer. Took it in on a rainy day and man, was it making a awful noise. After the "fix" the noise returned 20 meters down the road from the Dealer. Maybe try reversing the blade. Keep you informed.
Old Sep 22, 2006 | 01:03 PM
edstroyer's Avatar
I just snapped a PIX of the Passenger side wiper. I''ll upload it once I get home this evening.
The passenger side wiper was the one making noise for me also. If you look at your passenger-side wiper, you can clearly see a bunch words in braille all along one of the sides.
To test my theory, I reversed the wiper so the words would rub against the glass while coming up and sure enough it made a noise. I used a garden hose which had different spraying effects that I used during the test by the way!
At lease on my Fit, the solution is to have the words on the wiper rub on the way down! Hope this info helps...
Old Sep 22, 2006 | 08:28 PM
edstroyer's Avatar
In this pix your can see the writing on the blade thats causing the problem...
Old Sep 22, 2006 | 10:32 PM
larry2step's Avatar
My passenger wiper chatters also, and only when traveling upwards. The dealer replaced the blade (I was told the inserts were non-changable) but that didn't help. I think the problem is caused by the wiper arm pressing too strongly against the windshield. If this is correct, then the factory needs to releive the tension on the wiper arm prior to installation. My dealer couldn't replicate the problem and was reluctant to replace the blade but finally agreed to give it a try.
Old Sep 23, 2006 | 02:01 AM
Halcyon's Avatar
I was misting yesterday and i had the same problem. The passenger wiper was crazy loud even with music blaring. I will have to fix this too.
Old Sep 24, 2006 | 04:58 PM
MisFIT's Avatar
Ok so I reversed the assenger side blade and the chatter is gone for now. Thanks for the tip!
Old Sep 24, 2006 | 08:51 PM
joe FIT's Avatar
I'm stumped, how does one take the rubber blade out of the housing, the housing seems to snap out of the arm as mormal, and the clip over the middle is easily taken off, I just cant figure out how to get the rubber blade out to turn it the other way, to get rid of the noise mine makes also.
Old Sep 25, 2006 | 07:47 PM
edstroyer's Avatar
The housing/arm is rubber and flexible and the blade slides out by bending the tip. You'll see a flat-thin-metal bar. Slide that out along with the rubber blade.
Old Sep 26, 2006 | 11:22 AM
docjim2's Avatar
blade length
Originally Posted by DewaltDakota
Trico makes the teflon blades. I bought mine at the local Advance Auto Parts. It takes a 24" and a 16"... though I think a 15" would fit better. Even Honda seems to know that the 16" is too big, since they specifically notched the window trim for the blade to sweep across it.
I measured mine and my passenger side is 16" but the driver side is 23 3/4
which means that 24 & 16 should fit?
Did anyone know that the PIAA makes a carbon fiber style?
Anyone know how much they cost? My nearest dealer is 25 miles away!
Old Oct 1, 2006 | 10:57 PM
StormSilverGD3's Avatar
Just popping in to confirm that I flipped my passenger side wiper blade insert over and it stopped the wiper from skipping.
Old Oct 2, 2006 | 09:07 AM
I too flipped the wiper blade over and problem solved after 3 months of noise in the rain. The dealer cleaned my blades, cleaned my window, and was about to remove and replace everything when I told him about the fix for the fit which I read on this forum. He said I was crazy and that it would never work. I left him scratching his head in the parking lot on a "quiet" rainy day. Thanks for the tip!!
Jon
Old Oct 2, 2006 | 09:57 AM
  #32
wyy183's Avatar
Looks like the "flip" is the magic thing!! I did mine and it is now silent! WOO HOO!!!
Old Oct 2, 2006 | 05:27 PM
  #33
htewam's Avatar
Flipped mine around but waiting for a good (drizzly) day to test it out -- shouldn't have to wait long for a bit of rain in Seattle :-)
If this fix really looks good, perhaps one of the moderators can sticky this over in the Do It Yourself section so that others can take advantage of it.
EDIT - 07Oct06 - The rains over the last couple of days shows that this really works -- Great Work!
Old Oct 5, 2006 | 01:50 AM
  #34
aejazz's Avatar
So did Edstroyer's trick work for you, StormSilverGD3?
We had our first rain today in the Bay Area and yes, the wipers made an obnoxious rubbing/hoping noise whether clearing light mist or heavier rain. Reversing the blades sounds like the least time consuming and cheapest solution...so it would be nice to know if it worked for at least 2 folks. Thanks.
---oh...never mind. In posting this, several replies popped up showing that quite a few have found this fix to work. Thanks again.
Old Oct 6, 2006 | 03:53 PM
  #35
joe FIT's Avatar
reversing the right side blade, worked for me.
Old Oct 6, 2006 | 05:32 PM
  #36
GoFits's Avatar
try rain x too..reduces friction. plus really helps in heavy rains on the interstate.
Old Oct 6, 2006 | 05:53 PM
  #37
Packy's Avatar
Frequent FitFreak Poster
Gonna try reversing the driver's blade today... it's been chattering all day since it has been misting here off and on. Thanks for the tip, hope it works!
Old Oct 7, 2006 | 02:04 AM
  #38
aejazz's Avatar
Fix worked for me!
Thanks folks. I reversed the blades and immediately the noise is gone.
--ae
Old Oct 7, 2006 | 02:18 AM
  #39
Packy's Avatar
It did work for me!! I reversed my driver's side blade (had the writing on the top side) and it doesn't skip! Even when it's completely dry!
Old Oct 7, 2006 | 08:54 AM
  #40
Wave's Avatar
I can't believe how easy this "fix" is. Damn blades were driving me crazy!
