ultra rear sway bar
Old Jul 17, 2014 | 04:25 AM
lee lrd's Avatar
ultra rear sway bar
Hi,
i have a GD model uk spec sport,
i have lowered my car on eibachsport springs but feel the rear could do with something more so was looking at ultra racing rear sway bar..
i have been in touch with ultraracing but in talks with them they advised that the sway bar may catch on my exhaust pipework... i have an after market inox rear silencer.
I just wondered if any of you on here run ultra racing sway bars with after market exhausts and have any issues?
Old Jul 17, 2014 | 06:43 AM
DWils's Avatar
Sorry, I've got a Progress. Have you tried searching for the brand of rear sway bar you're looking for?
Old Jul 17, 2014 | 07:27 AM
lee lrd's Avatar
yeah have run searches but noone mentions any issues, but ultra racing said they cant commit to saying it will be ok, they say its where the bar will cross the exhaust pipe it could cause issue due to the larger diametre pipe work.
just dont wanna buy it find it doent fit then get stuck with it as in the UK we dont seem to have much of tuning craze for the jazz/fit so will be hard to resell the bar
Old Jul 17, 2014 | 11:24 AM
DWils's Avatar
How much larger is the exhaust than stock?
Old Jul 17, 2014 | 04:23 PM
lee lrd's Avatar
Dont think its a whole lot bigger, probably about 2inch i just dont no how much clearance the ultra bat has on stock exhausts
Old Jul 17, 2014 | 07:15 PM
Rollerboots666's Avatar
I really like the UR products but sometimes you have to modify them to fit.
I have the UR front, rear, and C-pilar bars for my GD3. On the front strut I had to drill out the holes on the strut tower (on the vehicle) to put a heavier bolt set-up. The rear strut bar was a direct fit. The C-pilar was a pain. Had to remove the the seat belts and use spacer to the head liner to get that bar to work.
Good luck with the product and please follow up with the fitment if you decide to go if UR.
Old Oct 17, 2014 | 05:12 AM
lee lrd's Avatar
ended up getting a whiteline 3 point adjustable bar...
set it on the middle setting, then had full alignment, currently running eibach springs and camber bolts,
the car is now sooooo nice to drive, even on the uk's wet roads its so stable
Old Oct 30, 2014 | 09:23 AM
lee lrd's Avatar
will be upping the stiffness of the whiteline bar to its hardest setting soon to see just how well it will perform... will update you all soon
Old Oct 31, 2014 | 10:37 PM
I'm assuming the Whiteline SB is for the front? I never heard of a rear SB for the fit being adjustable.
Old Nov 2, 2014 | 05:01 AM
lee lrd's Avatar
Nope its the rear lower anti sway bar. It has 3 adjuster holes said to give diffrrent levels of stiffness. Will report back one ive tried it
Old Nov 2, 2014 | 05:03 AM
lee lrd's Avatar
[QUOTE=lee lrd;1275109]Nope its the rear lower anti sway bar. It has 3 adjuster holes said to give diffrrent levels of stiffness. Will report back one ive tried it[/QUOTE. http://www.europerformance.co.uk/pages/products/category_results.mhtml?category=whitelineswaybars& car=hondajazz&manufacturer=whiteline&sub_category= 1
Old Nov 2, 2014 | 02:07 PM
Do you have a pic of the SB? Curious how this mounts compared to the Progress.
Old Nov 3, 2014 | 07:42 AM
lee lrd's Avatar
in this page you can see a pic of it,
GD Jazz Whiteline rear anti roll bar
there are 2 u clamps that bolt the bar to the tail arm, then there are little '8'shaped brackets that bolts to the side of the strut and then the sway bar bolts to it also..
weird set up compared to what ive seen on other cars, was fiddly to fit but definatley 100% improvement in handling
quick92ciFit
Mar 26, 2010 11:53 PM
Cadwgawn
Aug 29, 2009 05:55 PM
docjim2
May 5, 2009 08:59 AM
kylerwho
15
Dec 30, 2008 03:06 AM
mkg673
Dec 3, 2008 07:30 PM
