Wheel Alignment - Front only or four wheel?
Old Aug 12, 2014 | 11:55 AM
EQB356's Avatar
Even the Helm's manual - bought so impetuously and at great expense - doesn't specify. It gives the settings for all wheels but I still find no specific directions to check/adjust rear alignment for my Base 2012.
What has been your experience and current advice, please?
Thanks.
Old Aug 12, 2014 | 12:17 PM
only the front toe is adjustable on this car in stock form. its a VERY basic system, but effective.
Old Aug 12, 2014 | 12:29 PM
EQB356's Avatar
And thanks to you, Kenchan!
Old Aug 12, 2014 | 12:31 PM
np. if you buy camber bolts for the front (SPC makes them), you can do the toe and camber. i have the spc bolts i bought from tirerack. works great, dialed in at -1.5 degrees, zero toe-in for my swifts with RE760 tires.
Old Aug 13, 2014 | 03:07 AM
raytseng's Avatar
i believe the honda service manual advice for the rear is just the simplistic inspect for damaged suspension parts and replace, and/or straighten frame damage
knm345
Apr 12, 2013 01:45 AM
matrix02
Sep 8, 2010 01:10 AM
c_mack9
23
May 8, 2008 12:01 AM
bdk323
Apr 17, 2008 10:57 PM
cheebz
23
Jan 7, 2008 11:33 AM
