Any issues to using these bulbs?
Old Aug 15, 2014 | 10:18 AM
F1Flagger's Avatar
Robot Check Robot Check
Will they cause any over heating issues with wires?
Old Aug 15, 2014 | 11:45 AM
DrewE's Avatar
You shouldn't have an issue with the wires themselves, particularly as they're protected by fuses.
You may however have problems with fuses blowing, and should you replace them with higher ampacity fuses, you would risk wire damage and fire and so forth. You also could very well have problems with the reflectors/housings or connectors overheating and melting, burning, or discoloring—since these bulbs generate about twice as much heat as the stock bulbs. You also would be breaking the law by driving on the public roads using these bulbs; there's a reason why they're marketed for "off road use."
All in all, I don't recommend using them.
Old Aug 15, 2014 | 01:22 PM
spreadhead's Avatar
They probably won't last long. I used to use Osram Silverstars (not Sylvania Silverstars). I quit using them because they only lasted 6 - 8 months.
Old Aug 16, 2014 | 10:48 AM
Carbuff2's Avatar
80/100 watt bulbs require nearly TWICE the amperage as the stock bulbs.
You are playing with fire (literally!) if you just plug and play those bulbs.
When we ran performance rallies and high-amperage bulbs, we always used heavy wire direct from the battery and switched them with relays. That's the safe way to go.
Old Aug 16, 2014 | 09:51 PM
apexanimal's Avatar
stick with +30 bulbs for best balance between stock life and more light on the road, and you can do +50's if they make them for our bulbs...
Daniel Stern Lighting Consultancy and Supply
Old Aug 23, 2014 | 08:03 AM
rodpaine's Avatar
Carbuff2 is CORRECT! You'll fry some electrical items with these high amperage lamps! I've done a number of high wattage headlight conversions and voltage drop testing. Take a look at these two links on my BMW web site...
Modifications and Resources
Lighting Voltage Drop
There are also comments about headlamp changes on my Honda Fit web page.
-Rod
kered424
Aug 3, 2012 09:50 AM
Morair
May 9, 2012 08:26 AM
sdiesel619
Oct 18, 2010 01:21 PM
mnapuran
Mar 28, 2008 02:53 AM
pedaler
Nov 28, 2006 11:51 AM
