Opions on KWSC issue - Belt slippage at high/hard/fast RPM
Old Aug 30, 2014 | 10:20 PM
lightyear22's Avatar
I changed the pulley on my rotrex to a 85mm pulley from a 95mm pulley. The 95mm pulley had about a 75% belt wrap with a 2005mm effective length belt. I changed the belt to a 1994mm belt. I have been having some issues with belt slippage and I am guessing at the supercharger. Now at about 5kRPM I see around 7# of boost and then it stalls after from the slippage. I am using Gates belts and having to cut a rib or 2 off. I always thought the 2005mm belt was too long as I would have my alternator pulled back almost to the radiator for correct tightness with the 95mm. I have my alternator about 3/4 back with my current setup. I am considering getting a 10mm larger idler pulley to give me more belt wrap on the pulley. Does anyone know the make of the original idler for the KW system? I plan to continue with the 1994mm belt. The gates belt is not a green stripe HD belt. I have read a lot about the gatorback belts and use in SC setups. I tried one and had to cut a rib off and it shredded on me in park. I can try another one. What belts everyone else using? I know one other person that changed to the 85mm. Havent heard of any issues. I have tried about 4-5 belts and I will not use belt dressing! Any help appreciated. Thanks
Old Sep 30, 2014 | 08:40 PM
All fixed. Went to a 1980mm from a 1995mm belt with the alternator about a 1/4 of a inch from the loosest position. It is a actual gates 5 rib belt so no more cutting. Tension is good. I need to bring the rev limiter closer to stock so i don't over spin the S/C. Boost levels have dropped since header and test pipe. Got things flowing through. 11psi at 6900, this is where the limits of the S/C are achieved.
Old Sep 30, 2014 | 08:44 PM
Hootie's Avatar
Nice! Good to hear that you've finally gotten your drive belt situated.
Old Sep 30, 2014 | 11:27 PM
Myxalplyx's Avatar
11psi? Wow! Your car should be moving now. Nice! Congrats on the fix.
Old Oct 1, 2014 | 07:47 AM
These tires aren't going to last long. I am thinking about redoing the piping from the S/C to the intake next, maybe a different inter-cooler some how. I remember OJ telling me that IC restricts the air flow around 12psi. My air temps are kinda high still and am looking into a CF hood that I could do a scoop or NACA duct to the air breather. I did see a hood that had decorative vents almost where the intake and IC sit. I just worry that the S/C and intake could take on too much water if in the rain.
grommet
Apr 27, 2026 09:57 PM
jilm
Apr 13, 2016 06:22 PM
hazzard
Nov 20, 2013 01:38 AM
Marrk
Oct 23, 2009 07:32 PM
