Just put on intake, now CEL, help
Old Sep 6, 2006 | 04:53 PM
VividBlueFit's Avatar
its a power adder shortram, i got the sensor in the back mounted with a groumet and drilled in place. I put a breather filter on the copper tubed crank case and whatever that other pipe is over the end. Does that have to go into the intake?
Old Sep 6, 2006 | 05:04 PM
Old Sep 6, 2006 | 11:06 PM
Jimmy101's Avatar
What is that little blue filter? and what does it vent?
Old Sep 6, 2006 | 11:08 PM
TomiGunz's Avatar
Frequent FitFreak Poster
Where the blue filter is, it was connected to the stock intake box. So I don't think it matters if you installed it to the aftermarket intake or not. I put a blue filter on that spot too..
Old Sep 6, 2006 | 11:22 PM
well, other than the sensor on the top, which i remounted, the rest nothing else changed..
wonder if i have to reset the ECU or something?
Old Sep 7, 2006 | 01:11 AM
vbo's Avatar
vbo
You are sure you have air flow can pass into this filter ???
Try ecu reset (disconect - baterie 10min), or read dtc code with odb2 reader.
Old Sep 7, 2006 | 06:40 AM
sillypuddy's Avatar
Someone that Posts too much
Originally Posted by claymore
Jump your diagnostic connector and let us know the code you are throwing. And you really need to resize your photos down to 600-700k ...these are massive makes them hard to see and LONG time to load.
as mod you should remove his pictures until he resizes them, since it's like a nightmare to load
-joe
Old Sep 7, 2006 | 09:46 AM
marokero's Avatar
If I could read a OBD2 code, would I just clear it or resetting the ECU is needed (disconnecting the battery)?
Old Sep 7, 2006 | 09:58 AM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
maybe its due to the sensor location, cars can be picky! and it looks like an ebay intake.. on the suzuki 04+ there is no way you can put an intake on that car w/out throwing a CEL.. so mabye its the quality of the intake?
Old Sep 7, 2006 | 11:00 AM
TomiGunz's Avatar
Did you see my intake? It's like putting PVC pipes together. Didn't throw a code at all. I'm actually enjoying the power..
Old Sep 7, 2006 | 11:24 AM
TheDanger's Avatar
Reset your ecu by disconnecting the battery and reconnecting. If its still on after that check your MAF sensor and make sure it didnt get any grease/dirt on it.
Old Sep 7, 2006 | 11:31 AM
will it screw up the radio?
Old Sep 7, 2006 | 12:33 PM
805FitSport's Avatar
why not just pull the ECU fuse.... just a thought.
Old Sep 7, 2006 | 12:48 PM
TomiGunz's Avatar
Have your radio code and stations written down and have a watch because if you disconnect your battery you will lose the radio code, station and time and have to reset them.
Mine actually saved all the stations and settings after I unplugged the battery.
Old Sep 7, 2006 | 03:42 PM
dmxsoulja3's Avatar
Maybe if a Moderator hadn't moved my HOW TO intall the INJEN intake into a thread about an exhaust he would have had the basic instructions on how to remove the negative battery cable first...just a thought.
quangalang's Avatar
honda doesnt use MAF that sensor that you see is the air temp sensor.
I dont see anything wrong with the set up but go pull a code see what code the car is throwing and go from there
Old Sep 7, 2006 | 03:49 PM
dmxsoulja3's Avatar
Don't even bother pulling the code, reset the ECU first, it could have just been an all of a sudden thing...reset it...it probably won't come back on.
Old Sep 7, 2006 | 07:19 PM
TheDanger's Avatar
My bad used to my old xb...used to happen to so many owners and that was the usual problem. I still suggest resetting the ecu though.
Old Sep 7, 2006 | 10:12 PM
reset the ECU, lights gone, thanks guys
Old Sep 8, 2006 | 01:07 AM
vbo's Avatar
vbo
If you disconnect the IAT sensor and reconnect, a DTC code come.
That's possible it's it.
