Brake Fluid Flush
Old Sep 8, 2014 | 07:41 PM
fitowner10's Avatar
Brake Fluid Flush
So, I found the thread here: https://www.fitfreak.net/forums/fit-...port-auto.html
that shows you pretty much how to do the job. My question is, why is the turkey baster needed? Why not just bleed through the lines and add new fluid as the master reservoir drains down? It just seems redundant to me. I guess you'd want as little old fluid into the system as possible, but it's not like there's gonna be anything in there that can't come out on the other end?
Also, is DOT 4 fluid better than using OEM Honda DOT 3? thanks
Old Sep 9, 2014 | 07:40 AM
Carbuff2's Avatar
Sucking the fluid from the reservoir saves time, that's all. You are going to pump fluid through until it comes out clean at the bleeders, anyway.
There were some news items a couple years ago about master cylinder failures on Hondas and Toyotas because of some ingredient that the aftermarket brands didn't have. ???
DOT4 has a slightly higher boiling point than DOT3 and supposedly is "Low Moisture Absorbing" ... hence I USED to use it on all my cars. Now I use either the Honda stuff or DOT4.
Never had a problem either way.
Old Sep 9, 2014 | 07:58 AM
n9cv's Avatar
DOT 4 fluid has a higher WET boiling point than DOT 3. It also will mix with DOT 3 so it does not hurt to change to DOT 4 during a flush.
On a Fit I can not imagine needing DOT 4 because of the size of the car and the size of the brakes. That said, all I use here is DOT 4 and I will put DOT 4 in the Fit when I flush the lines.
The reason for sucking all of the fluid out of the master cylinder reservoir and replacing it with fresh fluid before starting the flush is brake fluid is hygroscopic. Meaning it attracts moisture out of of the air.
When moisture combines with the brake fluid it lowers it's boiling point. So you need fresh fluid in the reservoir when you start pumping it into the system.
Old Sep 9, 2014 | 07:57 PM
fitowner10's Avatar
I know it absorbs moisture and all that, but it's gonna be drained until new fluid comes out of the lines anyway? I can see it taking a bit longer, but if it means one less tool to buy/keep track of, and only a 5-pedal-press difference? thanks
Old Sep 9, 2014 | 08:36 PM
Carbuff2's Avatar
Well, you CAN use the baster for cooking afterwards....but PLEASE wash it out first!
JerryHughes
Jul 13, 2019 11:09 AM
Gekisen
27
Jun 23, 2019 11:53 AM
accordguyintake
SoCal Classifieds
Dec 23, 2010 08:34 PM
Kofi Anim-Appiah
Aug 6, 2005 04:43 PM
chibitul
Jul 24, 2005 05:32 AM
