GD3 & Swift Springs
Old Sep 26, 2014 | 08:42 PM
akacree's Avatar
GD3 & Swift Springs
Hello all. First post: The OEM rear springs bottom out with a few hundred pounds in the rear.. no news to most of you, I'm sure.
My setup: Enkei RPF1s 15x7, wrapped by 195-50 tires, OEM shocks.
If I change over to the Swift progressive springs & stay with the OEM shocks, will I bottom-out with a similar load in the rear if I don't roll the fender lip?
I'm interested in a comfy ride for my daily driver. It's a 60/40 weight distributioned 1.5 liter, so "sporty" anything is a bit of a silly trajectory, so with that in mind, my interests are:
  • comfy ride
  • slightly more aggressive stance
  • minimal to no bottoming-out
Cheers all. And thank you for all the useful info!
Old Sep 30, 2014 | 10:15 PM
What offset are your Enkeis?
Old Oct 1, 2014 | 12:44 AM
Hootie's Avatar
IF your 15x7 RPF1s are the +41mm offset, you'll more than likely be ok in terms of clearance without cargo. I'd love to give an honest answer regarding how much they sag when loaded but I haven't seen or heard anyone report running Swift springs with 200 to 300 lbs worth of cargo in the car.
On the other hand, if your RPF1s are the +35mm (or lower) offset then you'll have an increased chance of tire rub but should likely clear with little to no modifications when empty. Again, not sure what would happen with cargo.
Just as a thought... Since you are wanting to maintain a comfortable ride with the stiffer but progressive Swift springs you may want to invest in Koni's adjustable damping yellow shocks for the rear of the car. I believe Red Shift Chris is selling them on here if you're interested on getting more information regarding this.
Old Oct 1, 2014 | 05:33 PM
akacree's Avatar
I appreciate the responses.. thank you.
I installed the 41mm offset wheels, but added 10mm Project Kics spacers in the rear.
Old Oct 1, 2014 | 07:26 PM
Hootie's Avatar
Ditch the spacers, you'll very likely rub with the Swifts on then with a heavy load on. The reason being is the 10mm spacer will be lowering your wheel's offset from +41mm to +31.
Old Oct 1, 2014 | 07:53 PM
akacree's Avatar
Yea.. makes sense, but was hoping for a spring &/or shock solution w/o losing the spacers. I'd rather roll the fender lips before losing the flush look w/ the spacers.
Old Oct 1, 2014 | 08:57 PM
Then lower the car and hope that it solves your issue.
Removing the spacers will fix the rub. Worrying about how 'flush' your wheels are at stock height is just a bit silly IMO.
Old Oct 1, 2014 | 09:50 PM
akacree's Avatar
I'll reach out to Red Shift Chris. I appreciate the feedback Hootie.. thanks.
Old Oct 3, 2014 | 11:38 AM
p nut's Avatar
Definitely ditch the spacers. I was running 38+ Konigs and it rubbed like crazy. Rolled the fenders and trimmed some plastic bits, but still got some rubbing (I have 205/50 tires, though). I went to 45+ and is all good now, except slight rubbing up front when going over a dip with the wheel turned. Not bad, though.
Old Oct 6, 2014 | 07:27 PM
akacree's Avatar
Thanks p nut. Ditching the spacers, unfortunately, isn't an option at this juncture, as the mechanic that installed them hacked off a good amount of the wheel studs to flush the spacers. I'll have the fender lips rolled & see how it goes from there.
HavengaR
Feb 18, 2021 10:26 AM
Mazubo
Aug 25, 2017 09:17 PM
mangosmoody
May 8, 2017 03:04 PM
dels
Hawaii Community
Mar 31, 2011 05:25 AM
vincent001
May 1, 2009 05:07 PM
