Does anyone know how I can give 4 degree advance please;
Old Sep 12, 2006 | 03:25 PM
Kostas's Avatar
Hi there.
My Jazz is byfuel. Before one year I pun an LPG kit and now runs LPG. Because this fuel need more time to burn it self I must add about 3-5 degree advance.
Does anyone know how I can do that?
thanks
Old Sep 13, 2006 | 07:52 PM
sxthirteen's Avatar
aftermarket cam gears???
Old Sep 14, 2006 | 07:43 AM
Kostas's Avatar
Thanks but, this will effect on valves only. I do not need it.
I need to intervene on the spark plug timing (advance).
I mean I want to adjust the motor to burn the fuel earlier about 4 degrees.
Old Sep 15, 2006 | 01:00 AM
vbo's Avatar
vbo
S-afc 2 neo?
V-afc2 ?
Old Sep 17, 2006 | 02:48 AM
Kostas's Avatar
Originally Posted by vbo
S-afc 2 neo?
V-afc2 ?
It is not works but
thank you.
Old Oct 21, 2006 | 01:00 PM
Kostas's Avatar
Does any know if I take off the pulley, deled the mark and create a few degree earlier mark works?
Thanks guys.
Old Oct 26, 2006 | 04:58 PM
thecheat's Avatar
you may need to find out if hondata has programing that will allow you to change advance. I would look for an electronic soultion before you try a mechanical one.
Old Oct 26, 2006 | 07:20 PM
gettinafit's Avatar
I don't think that there is a mechanical solution in this case! When you used to turn a distributor, you were changing the ignition timing! And that is what you are looking to do, not change engine timming! Messing with engine timming would be bad! U need a computer solution! hope this helps!
Old Oct 27, 2006 | 08:04 AM
Kostas's Avatar
Unfortunately my car has not distributor so I can not adjust the timing advance for there.
Unfortunately hondata has not any program yet
us I asked in my country.
Unfortunately I look under of my car and I saw the timing sensor that is beside of pulley and is NOT read the pulley but it reads a cogwheel INSIDE of engine.
Old Oct 27, 2006 | 10:06 AM
gettinafit's Avatar
Smile Let me clarify!
I said the above, with knowledge that we no longer have distributors. Hence,
:"When you USED to turn a distributor, you were changing the ignition timing!"
WHen i said, "
that is what you are looking to do"
I meant changing ignition timing.
Just re-read it again slowly, you'll get it!
Sorry if I confused you. I was just elaborating that you can not do that and you must go the electronic way!
Old Oct 27, 2006 | 10:07 AM
gettinafit's Avatar
Even the electronic way by the way is changing ignition timing! Just in a different way without a dizzy!
Old Oct 27, 2006 | 02:58 PM
Kostas's Avatar
Do you know any company to product any project?
Hondata the most popular has not.
Old Oct 29, 2006 | 07:00 PM
gettinafit's Avatar
There really isn't much engine aftermarket performance modification products available yet for the L-series motors that you are correct. We're all waiting! Personally I'm waiting for the K-series mount kit to come out, then I'm scrapping the L-series!
Ridza
May 6, 2016 05:48 AM
kurobaxkaito
Dec 7, 2013 12:15 AM
Fit4luv
Jan 5, 2013 08:41 AM
Machiel
Jul 7, 2010 09:32 AM
anjingbalap
Jan 2, 2007 08:30 PM
