Lift Kit for a Honda Fit?
Old Oct 7, 2014 | 02:46 PM
Matwong92's Avatar
Hey all, I own a 2010 Honda Fit Sport. This winter I was thinking of putting a lift kit on my Fit with tires since I had a bad experience last winter. Is it possible to put a lift kit on a fit?
Old Oct 7, 2014 | 02:50 PM
MNfit's Avatar
just about anything is possible, with time and money. Is there a bolt on kit out there for the Fit? pretty sure there is not. With some back yard, redneck engineering I am sure you could figure something out.
Old Oct 7, 2014 | 03:07 PM
Waiz's Avatar
Avid FitFreak Poster
I don't think you would want to necessarily put a traditional truck style lift kit on a Fit
If you are serious but getting some additional ground clearance you could go the route of the official Honda Performance Dvision Fit Rally car
Rally Racing - Honda Performance Development
Here is that cars specs:
Rally Racing Parts - Honda Performance Development
From what I can tell they are using a custom Billstein coilover setup which you could also run a something similar and switch it out much easier than a truck style lift kit
Old Oct 15, 2014 | 04:55 PM
c0V3Ro's Avatar
Question
Over here we have very bumpy roads.
Increasing the wheel/tire diameter implicates in less acceleration. The L13A4 80HP CVT already got a poor one.
Thinking in using rubber spacers.
Old Nov 5, 2014 | 02:53 AM
gaustin70's Avatar
205/55R16 Tires?
I'm one of the few freaky people who actually want to raise my fit up a bit for more ground clearance. I drive my 2011 fit sport to three different farms I own and often out of town to rifle matches that put me on dirt roads with varying degrees of uneveness. I have a set of 205/55R16 tires I plan to install as a replacement for the stock 185/55R16 tires, which are about 1" in diameter larger, giving me about a 1/2" increase in ground clearance (every little bit helps). I'd rather not modify the suspension, so I'm going with what I percieve to be a modest tire upsize.
My question is has anyone else made this swap and have they had any problems with tire rub?
Old Nov 14, 2014 | 12:17 PM
slimchriz's Avatar
I'm not sure if the available coil overs will allow any but on my A4 Audi I used to raise them to max height in winter when I was living in Iowa as they plowed roads day after snow usually. I got stock +1.5" height and it was night and day difference on roads with up to 2' of snow hah!
Old Sep 27, 2015 | 01:27 PM
space egg's Avatar
i can verify that you can lift the fit 1/2" with taller tires.
try 195/65/r15 +40 offeset (or more) to gain 1/2" clearance height with no rubbing
Old Nov 12, 2015 | 10:58 PM
teamkitty's Avatar
Do you remember what brand of coils you had on your a4?
Old Nov 13, 2015 | 11:34 AM
bensenvill's Avatar
the 205 just makes it wider not taller.
as someone said before there are some spacers you can install to raise it a bit. also of interest may be that the base model spring/struts sit higher than the sport model (I've never been able to get numbers on that) but for reference, I have a good 4 finger gap between rubber and fender at all corners
Old Nov 13, 2015 | 11:55 AM
You're wrong. They are also taller.
Stop spreading misinformation.
Old Jun 13, 2016 | 04:30 AM
Pyts's Avatar
I realize this is an old thread, but having been a tire guy for a few years seeing this kinda stuff on one of the forums I use for sourcing build info is disheartening.
In tire size, the first number is the tread width (never bothered to learn the measurement unit but I assume metric because the alternative used primarily for larger light truck tires is us standard). The second number is an aspect ratio. The height number (second number set) for a tire size is actually represented as a percentage of the tire width. Example: 205/50/r15. The height is half the width. By adding width and maintaining the same height number you do infact increase overall diameter of the tire.
That pretty much sums up two years of my life.
Old Jun 13, 2016 | 01:02 PM
Fit Charlie's Avatar
Going from 185/55/16 to 205/55/16 doesn't just get you nearly a half inch of ride height, it drops you from 840 revs per mile to 811. That's 3.7% farther for every turn of the wheel, a nice bonus to your mpg if you spend more time cruising than playing stop/start.
Old Jun 13, 2016 | 03:20 PM
slimchriz's Avatar
Hey guys lots of confusion over tire size differences.
I created this spreadsheet with formula to do math for me.
you may find it useful. I could add the rotations as Charlie mentioned but I just was trying to get quick way to tell which tires will eat my fenders.
Let me know if anyone wants the rotations added. FYI there are calculators on the web as well but most are block by my work proxy servers so needed a local copy.
TireSizeCalc.xls
BlackUp
Apr 15, 2012 12:45 PM
mnapuran
Jul 28, 2008 03:39 PM
scoscheguy
May 4, 2008 10:08 PM
CuTeBoi
Feb 5, 2008 03:24 AM
JDMchris.com
784
Jan 31, 2008 02:49 PM
