'07 Fit leak through child seat anchor
Old Oct 8, 2014 | 10:22 PM
Eric Moss's Avatar
Exclamation '07 Fit leak through child seat anchor
After a rainfall I will open the child seat anchor cover to find about two tablespoons worth of water and some wet upholstery directly below the anchor. I have read through, literally, all the other threads regarding water leakage into the Fit and even sealed the cracks that tend to form near the top corners of the rear door opening, yet I still have water.
Is it possible that water is coming in via the antenna opening? I did a thorough inspection of the area and found nothing unusual. Has anyone else run into a similar problem even after sealing the cracks? Any help would be much appreciated, thanks!
Old Oct 9, 2014 | 04:18 AM
DWils's Avatar
Duplicate thread: https://www.fitfreak.net/forums/showthread.php?p=1269920#post1269920
Old Oct 13, 2014 | 08:25 AM
Dougr320's Avatar
Leak
Mine had the same leak for a lon time. This summer I took the black roof seam strips of and used GE silicon II caulk to resealed them. I also sealed around the rear hatch hinges and anywhere else the factory sealant had become brittle and started to crack. Silicon caulk may not have been he best choice but the leak has all but stopped for me. I may get a tiny drip in a heavy rain, but before it has a steady heavy leak.
Dsardone
Jun 23, 2021 01:10 PM
Eric Moss
Oct 9, 2014 09:09 AM
CartridgeBot
Sep 25, 2014 01:14 AM
DeeDee
Jun 14, 2013 12:47 AM
veteran13
Nov 1, 2009 04:37 PM
