I have what i think is a bad engine mount, have questions
Old Oct 9, 2014 | 12:34 PM
allmotormark's Avatar
I have a 2007 mt sport , it definitely feels like a bad engine mount. I can feel the engine vibrating through the car at idle and also while driving. its not a miss-fire.
my question is i have inspected the mounts the only mount i can see is bad is the torque mount in front of the transmission its ripped. i'm not sure if thats the cause of the vibration since it doesn't actually hold the engine. are the other mounts prone to failing? how can i tell if the passenger side mount is faulty? I can see the upper transmission mount and it seems fine.
thanks guys for any help
Old Oct 9, 2014 | 03:33 PM
MNfit's Avatar
a bad trans mount could be causing the vibrations. IF you can fiscally see the mount is torn why not replace that one then go from there?
Old Oct 9, 2014 | 03:36 PM
It's not the trans mount it's the torque mount In front of the trans. If it was the mount on top of the trans I would replace that first. Just trying to figure out how to check the passenger side mount as it looks like it's a hydraulic mount
Old Oct 9, 2014 | 06:11 PM
MNfit's Avatar
aw got it, sorry not really sure how you would go about checking that
Old Oct 10, 2014 | 01:16 PM
Marrk's Avatar
I, also, would like to know the answer to the OP's question.
88self
Jun 13, 2017 11:18 AM
MTLian
May 2, 2016 12:57 PM
mxl180
Sep 1, 2014 11:37 PM
koolkevin1107
Oct 8, 2012 07:33 PM
hernlui
Apr 26, 2009 02:44 AM
