Will these fit - wheels and snow tires
Old Nov 15, 2014 | 09:02 PM
andre181's Avatar
Today was our first decent snow and the GK doesn't do as good as my trusty GD3 did in the snow. The GD3 was awesome in snow with just all seasons. Never got stuck and was well controlled, even in 6-8 inches of snow. The GK with stock Bridgestones was all over the place in just an inch of snow.
So the hunt for wheels and snow tires begins! Unfortunately, I don't know too much about wheels, tires, and fitment.
Will these fit the Fit? (pardon the pun...) 2015 EX-L of course...
Sport Edition F2
16x7
40mm offset
5.47" backspacing
with 195/55/16 Dunlop Winter Maxx?
These are wider, will there be issues with rubbing?
And if they don't fit, what would you recommend?
Thanks in advance!
http://www.tirerack.com/wheels/Wheel...&association=1
http://www.tirerack.com/tires/tires....cleSearch=true
Old Nov 30, 2014 | 10:21 AM
Padawan's Avatar
For winter, the prevailing wisdom is that "narrower is better" so in this case I would pass on the 195 mm width.
If you follow the link below, you'll be able to select or create a winter package that's sized appropriate based on the wheel diameter you opt for, and it will be guaranteed by Tire Rack to fit (pun slightly intended) properly.
Unless you absolutely want a 16" wheel, I would suggest one of the 15" or 14" packages.
http://www.tirerack.com/snow/WinterP...toModClar=EX-L
Old Dec 31, 2014 | 11:32 AM
Apexracing's Avatar
16x7 +40 offset will poke allot in the front.
SilverEX15
Aug 10, 2014 07:06 AM
Maxmax1
Jun 10, 2014 05:28 PM
Highcountry
Oct 14, 2013 05:10 PM
henryb
Jan 15, 2011 07:23 PM
Darkstars
Sep 8, 2008 03:29 PM
