2008 Fit won't start in cold weather
Old Nov 17, 2014 | 10:58 AM
Benjamin Davies's Avatar
I have a 2008 Fit S, manual, 75,000 miles. This is my first winter, and might be my car's first winter as well. I bought it in Texas and recently moved to Minnesota.
Before the cold weather arrived I got my Fit serviced and the mechanic said it was in top shape. Over the past week it has been cold (-15 C / 10 F) and my Fit has been starting without a problem and running like a charm. Today it failed to start. Every time I turn the key, the dashboard lights turn on but I get a whirring/clicking sound and the engine doesn't start. Any ideas? Is the battery? The solenoid? The starter?
Old Nov 17, 2014 | 07:16 PM
DrewE's Avatar
It's probably the battery. If it's the original battery, and so six or seven years old, I would just replace it without bothering to test it as it's pretty much at (or some would say beyond) the end of its useful life. Battery performance goes down in cold weather, while the engine needs more juice to start (due to the oil thickening some in the cold weather and the gasoline not vaporizing as readily or effectively). If, on the other hand, the battery is relatively new, go someplace and have it and the alternator tested. Some auto parts stores will do this for free.
You should be able to get the car started with a quick jump or probably by putting the battery on a charger for a little while. If you tend to make a lot of short, brief trips without any longer drives, it may be worth your time to get a small battery maintainer charger, as you probably aren't driving enough for the battery to fully recharge.
Old Nov 17, 2014 | 07:33 PM
Thanks for the advice. I was able to jump the car later and went to get the battery tested. The battery was classified as bad and needed to be replaced. I got a new battery and everything is back to normal.
Old Nov 17, 2014 | 11:20 PM
john21031's Avatar
How much did you pay for the battery? Where did you buy it and what brand did you go with?
Old Nov 18, 2014 | 08:31 AM
Once I got my car jumped I went to Autozone since they were only a mile away. The only battery they had in stock that could fit was the Duracell Gold 151-R. After taxes it was $145.
Old Nov 18, 2014 | 09:53 AM
john21031's Avatar
Okay, sounds reasonable. And I am sure the battery has a few years of warranty?
Good luck.
Benjamin Davies
Dec 9, 2014 03:50 PM
Benjamin Davies
Nov 19, 2014 07:07 AM
Benjamin Davies
Nov 17, 2014 06:10 PM
Vacca Rabite
Jan 16, 2011 06:57 PM
Amageus
Feb 11, 2008 10:23 PM
