3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Just lowered my gk5 ex
Old Feb 4, 2015 | 10:55 AM
Nikoatnite's Avatar
5% TINT ALL THE WAY AROUND
LET ME KNOW WHAT YALL THINK.
Old Feb 4, 2015 | 11:32 AM
m_x's Avatar
m_x
I think you are bound to get a ticket with 5% tint, but I'm also crazy jealous that you went that dark because it looks awesome man!
Old Feb 4, 2015 | 11:57 AM
SR45's Avatar
Anyone would like to explain why lower the darn thing in the first place. I mean an explanation that actually makes sense ?
"The Disadvantages of Lowered Suspension
Increased bottoming out. One of the most common problems with lowered suspensions is that the vehicle can more easily hit the road when it bounces. Speed bumps can also be problematic. Contact with the ground can cause parts of the underside of the car to be seriously damaged. The oil pan and exhaust system are particularly vulnerable.
Uneven tire wear. In some cases, a lower suspension can cause tires to wear unevenly, or cause extreme wear patterns. Drivers should look out for this consequence when altering their suspension in any way.
Potential conflict with other parts. An even more dangerous consequence of a lowered suspension occurs when elements of the suspension system come into contact with other vehicle systems. Low suspensions can get caught up in anti-lock brake apparatus, sway bars, or even with the sidewalls of the tires. An incorrectly set up suspension can actually chew on tires, causing some serious potential risks.
Lifting and towing problems.For those who like to use manual jacks to raise a vehicle for routine maintenance, lowering the suspension can make a simple job a lot harder. Think about your access needs before shifting your car's frame lower toward the ground".
Old Feb 4, 2015 | 12:42 PM
Nikoatnite's Avatar
Lol I know I'm taking the chance it's just a fixit ticket I love the way it looks tho. Thanks tho.
Old Feb 4, 2015 | 01:09 PM
jhn's Avatar
jhn
JDM has them but the bumpers are a bit different than the USDM versions. May not work. You might just have to wait until they become available:
2015 + Honda Fit / JAZZ (GK3 / GK5) - CF-Spec Carbon
Old Feb 4, 2015 | 01:12 PM
jhn's Avatar
jhn
Because handling and looks.
With a 1.5" drop or less on this car, none of the issues you wrote are significant. Tire wear is the same after an alignment. Clearance is not a problem if you live in an area with good pavement.
As the old saying goes goes, if you have to ask, it's not for you. Don't lower your car.
Old Feb 4, 2015 | 05:06 PM
MyFreakFit's Avatar
Fuel economy can also improve with less air flow going under the car.
Old Feb 4, 2015 | 05:17 PM
Fit-ed's Avatar
You are saying that the car will more easily hit the road when it is lowered. This assumption only works if the lowering springs are softer or as soft as the stock spring. This is usually not the case and the spring is usually harder than stock, reducing the bounciness of the car.
Also, lowering the car lowers the center of gravity. A lower center of gravity means less body roll when cornering and it also means less weight transfered to the front wheels when braking.
Furthermore, no suspension will hit the inner sidewall of your tires when the car is lowered if you have wheels that clear your components.. and I'm not exactly sure how a lowered car will cause the sway bar to make contact with anything else... unless you're gunning it through the whoops section on a dirt bike track. The only thing that moves when you lower the car (other than the car itself) is the lower control arm, which moves upward.. not that that can't be corrected with RCAs (Roll Center Adjusters)
Old Feb 11, 2015 | 09:22 PM
heybeavis's Avatar
Hey grandpa, you don't get to post a question and then type out your rant, as if you actually wanted people to answer your question, but to make sure we didn't mistake your sarcasm and snark before doing so.
Get over yourself. Lower or don't, but stop caring about what others do and making sure we have to listen to it.
Old Feb 11, 2015 | 09:36 PM
bzdang's Avatar
I think it's like my son's pants, I don't get it but it works for him.
Old Mar 10, 2015 | 05:20 AM
YourConfused's Avatar
Made me laugh.
Old May 20, 2015 | 05:02 AM
jukeboxx13's Avatar
Very nice.
I want to lower mine when the new swift springs come out but It wont be as low as yours.
My 15 Fit EX is also white btw with 35% tint in the front and 18% in the back.
Old May 20, 2015 | 11:58 AM
CN_Fit's Avatar
Originally Posted by jukeboxx13
Very nice.
And there is a very good reason why it ain't lower. I'll post a write up soon, but rest assured swift's will work well enough on this car.
Old Jul 1, 2015 | 01:32 PM
luisochoa's Avatar
Gk5
hey bro, What is the part # for the H&R springs. i want to order some.
Old Nov 24, 2015 | 08:08 PM
.RYAN's Avatar
What's the spring rates? Google can't even find me info for the GK5 H&R's.
Linksy
Oct 30, 2023 01:21 AM
bbigmouthh
85
Jul 17, 2021 06:49 PM
CarbonTek
Feb 4, 2019 12:54 PM
bosho.777
17
May 17, 2018 10:19 PM
Connor Keyser
May 17, 2015 12:58 AM
