15x6 wheel with 47mm or more offset?
Old Feb 6, 2015 | 08:40 PM
glockprime's Avatar
After a ton of searching, I need your help:
What wheels are available in 15x6 with 47mm or more offset?
Old Feb 6, 2015 | 09:48 PM
OEM.
Why are you looking for that sizing?
Old Feb 6, 2015 | 10:04 PM
glockprime's Avatar
For autox street class... want something lighter than stock... details here:
https://www.fitfreak.net/forums/fit-...ss-auto-x.html
Old Feb 6, 2015 | 11:04 PM
Old Feb 7, 2015 | 12:26 AM
glockprime's Avatar
Nice! Thanks. When I use the filters on that site, there are no results. Have to know about that wheel specifically. I see it on the Weds site now.
Old Feb 7, 2015 | 12:34 AM
glockprime's Avatar
Looks like the SA15R is a little lighter.
Old Feb 8, 2015 | 06:38 PM
I wouldn't doubt it, I just like the SA10R
Old Feb 8, 2015 | 07:33 PM
macbuddy's Avatar
Saturn Sawtooth
I think the specs on the Saturn Sawtooth wheels might work for you.
Old Feb 25, 2015 | 02:54 PM
Fit-ed's Avatar
Maybe try SSR GTV01? or 02?
The GTV02 would look something like this^
Old Feb 25, 2015 | 04:06 PM
glockprime's Avatar
wrong offset
Old Feb 25, 2015 | 04:28 PM
Fit-ed's Avatar
wrong offset
They make them in 15x6 +45 only 2mm off from what you posted...
Old Feb 25, 2015 | 04:33 PM
glockprime's Avatar
sorry, 2mm off is still 2mm off... there are a lot more options if you can violate the >=47mm requirement
Old Feb 25, 2015 | 04:59 PM
Fit-ed's Avatar
They do make the similar Work Emotion 11R in 15x6.0 +48 but idk how light that wheel is. There's also the Volk RE30 in the same size.
Old Feb 25, 2015 | 11:40 PM
glockprime's Avatar
I only see the Work Emotion 11R with +52 offset (which is fine, but +48 would be better):
http://www.workwheelsusa.com/media/w...R_SPEC10A1.pdf
Are you sure the Volk RE30 comes in 15x6?
Looks like the Weds SA15R is the front runner so far.
Old Feb 26, 2015 | 11:33 AM
Fit-ed's Avatar
Old Feb 28, 2015 | 07:44 PM
Rollerboots666's Avatar
What is your plans as far as set-up for AutoX Glockprime?
Old Mar 11, 2015 | 01:18 AM
glockprime's Avatar
For wheels and tires, the plan is:
15x6 Weds SA-15R 48mm offset
205/50/15 Azenis RT615K
Double crash bolts in front for max neg camber. ~0.25" front toe out.
Haven't figured out what the stiffest rear sway bar is yet.
Old Nov 25, 2015 | 12:36 PM
glockprime's Avatar
8strung
Feb 2, 2018 02:41 PM
Skimmer
Racing
17
Nov 25, 2015 07:06 PM
Necos07
Jul 17, 2009 08:11 AM
Apex77
Sep 14, 2007 04:37 AM
FireFit
Sep 13, 2006 03:38 PM
