2011 crz rear axle conversion for ge8???
Hey guys,
I just found a totaled 2011 honda crz around where i live in a junkyard and would like to know if i can take the rear axle to convert my ge8 to rear disc and if the front seats fit. would like to know as well if there any useful parts can i take fromthe crz for my fit.
Thanks
Thanks
Hey guys,
Thanks
Thanks
but then you have to use a 5 bolt pattern wheel since CR-Z used a 5 bolt pattern.
I do have a 4bolt pattern rear wheel hub/bearing in NEW Condition (0 miles) that I will took off from my JDM Fit RS rear wheel axle conversion that should fit your CR-Z axle.
I plan to sell it if you are interested,
so you can use the USED CR-Z axle from the junk yard,
but keep your current wheel,
plus you get a NEW condition bearing/rear wheel hub instead of the OLD bearing from that CR-Z axle.
Thanks
PM how much you want and what else would i need to make the conversion???...
I am pretty sure you can convert your GE8 to rear disc using the CR-Z rear axle,
Thanks
Thanks
BlueBoogers
Aug 8, 2012 04:43 PM
