FS: Alpine CDE-147BT with EVERYTHING needed for install
Old Mar 8, 2015 | 07:06 PM
Fast1one's Avatar
I am moving to an external processor so this unit will need to go. It's still installed as you can see below. This is a bolt on affair and will literally take you 20 minutes or less to install. What you are getting:
-Alpine 147BT with all original accessories and box
-Wiring harness soldered and heat shrink, ready to plug in
-Antenna Adapter
-Steering wheel controls adapter
-OEM 2012-2013 Navi gunmetal trim and bracket
-Accord din pocket with door
The good:
-Purchased authorized from Crutchfield a few months prior.
-9-band PEQ and time alignment
-Bluetooth, Aux, USB connectivity
The bad:
-I goofed up and cut the navi bracket too much on the inside lip when adding the din pocket. You can't see it at all once installed.
-Even with the trim ring installed on the HU, you can still see a gap around the HU. I don't think the OEM Navigation is a standard opening.
$180 shipped to the CONTUS. No trades.
Old Mar 8, 2015 | 10:54 PM
getinthezone's Avatar
oh thats neat
fatdoggie
27
Jan 13, 2017 01:12 PM
jrp07f
Mar 31, 2011 03:04 PM
hms09fit
Nov 14, 2010 09:13 AM
09blackfit
Apr 13, 2009 07:22 PM
blackfity
Feb 14, 2008 08:36 PM
