3rd Gen GK Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 3rd Gen GK Honda Fit
DIY: Projector Headlights
Old Mar 25, 2015 | 01:45 AM
Kdawgz's Avatar
Okay, I finally got time to install my first retrofit. Been extremely busy with school, work, and what not...
What you need:
- 2-3 days of free time (spring break and scheduled myself to have no work
-Copies of morimoto...same exact stuff:
Amazon.com: Nilight® 2.5" MINI HID BIXENON PROJECTOR LENS FOR H1 BULB CAR GIFT:CHROME SHROUND: Automotive Amazon.com: Nilight® 2.5" MINI HID BIXENON PROJECTOR LENS FOR H1 BULB CAR GIFT:CHROME SHROUND: Automotive
- 1 can spray paint and 1 can paint promoter (optional)
- teflon tape or some sort of grease for the nut....I learned my lessons afterwards. I ran into the issue of crooked beam and stripped threads. My solution was super gluing adapter and holding + aligning the projector while they were running on the car. I had to work really really fast. Plus I was freezing my butt off out in the garage.
-your typical tools....I assume you know
-h1 hid kit with h1 relay
-h8 fogs with relay (optional)
So taking off the bumper is the easy part. There are 2 screws on the both wheel sides. 2 screws are at the bottom. 4 clips need to be removed underneath. 5 or 6 clips on the grille...didn't attach pics because it's very self-explanatory.
Painted the shrouds matte black with VHT spray paint. Use a paint promoter to make the paint stick.
There are 4 screws and 1 clip holding the headlight. They are very easy to point out.
I put the headlight in the oven at 250°F for 10 minutes. Surrounding the perimeter of the headlights are 4 screws. I wasn't afraid of being aggressive. I grabbed it from the apex part and just pulled it. I didn't do much to the clips.
After inspecting the headlight bowl I realized that it was difficult to take out due to a clip. So I used a dremel to remove the glare shield.
Spray paint the bowl matte black...
You can see below where I made the cut to the glare shield.
I don't know what people are talking about that it's hard to find ground...
First ground:
Second ground:
Ballast placement: HID + Fogs (NEW)
OLD placement for fogs: Both of which are good spots
I put the headlight back in the oven for 15 minutes screwed it in place, then reheat for another 15 minutes at 250°F. Firmly pressed on all the sides and made sure all the screws were tightened.
Result:
Tips:
-wear gloves
-plan for the worst (this is everyday car) so I knew that I had to get things done ASAP
-use heat gun for fasting drying of paint or oven
Old Mar 25, 2015 | 08:21 AM
mdbrich's Avatar
I am curious to know if this handles the low / high beam. Since the fit uses one bulb to do low / high beam, and this retrofit has replaced that bulb.
If it does would it be possible to get a distance shot at night to display the beam angle for each high and low positions? Additionally could I see the headlight installed back onto the car.
Sorry if its a lot to ask for, but thanks in advance. It does look sweet as it is at the moment
Old Mar 25, 2015 | 03:23 PM
noripwr's Avatar
Next time instead of super glue use jb kwikweld steel stick. I think they sell for $5 at Home Depot. Gives you I believe 6-15 minutes to fix your beam adjustment before it hardens, then wait like an hour to cure. Ideally u want to adjust the beams with both lights on so they don't look wonky. Best to do this at around what 25 feet away so you know where each projector is pointing at.
Old Mar 27, 2015 | 03:41 AM
Kdawgz's Avatar
Old Apr 20, 2015 | 01:33 PM
Carz0159's Avatar
Wow! They look great! I wonder if there's a whole headlight assembly I can get...
Old Jul 4, 2015 | 08:21 PM
esnave09's Avatar
Nice write-up! Can't wait to do this to mine! What are the relays for? Do they prevent the car from almost stalling when they're first power on?
Old Jul 5, 2015 | 01:22 AM
Kdawgz's Avatar
You need h1 relay to plug into factory harness...otherwise you'll be stuck.
Old Jul 5, 2015 | 01:33 PM
esnave09's Avatar
Oh, duh. haha I guess I have D2S projectors, so mine's for H4. But should still do the same thing.
Also liked your locations for the HID ballasts. Not sure if I'll do that though, because last winter wreaked havoc on my fog ballasts (had to replace both of them, someone suggested because of the cold).
Old Aug 22, 2015 | 08:47 PM
Bigbadvoodooguru's Avatar
If you wanted to leave the reflector shield alone (chrome), can you do this without removing/cutting it?
Obv. still remove the headlamp and lens assembly, but can you leave the reflector in place?
Old Aug 28, 2015 | 09:56 AM
Kdawgz's Avatar
You have to remove the reflector shield has to come off if you're going to install projectors.
Old Aug 19, 2016 | 11:58 PM
328isawesome's Avatar
Does this have an impact on the car's warranty?
Old Aug 21, 2016 | 12:51 AM
Kdawgz's Avatar
Not really....when I took my car to the dealership for the recall they didn't say anything. In fact, they loved it!
Old Dec 11, 2016 | 05:56 PM
maxswisher's Avatar
Are the fits lights dual filament for the high beam? I am asking as I'm trying to figure out which installation guide to use for the Morimoto H1 Mini kit.
Old Feb 17, 2018 | 08:54 PM
CodemanGK5's Avatar
Yes they are. You want the H4 motorelay harness.
Old Apr 30, 2018 | 04:31 PM
evilchargerfan's Avatar
the painted housing looks real good. nice job!
Jephu
May 23, 2015 10:35 PM
danger69
Feb 9, 2014 02:46 PM
smeister
135
Nov 16, 2012 05:55 PM
HashiriyaS14
Apr 3, 2008 11:10 AM
Luichenwai
28
Jul 18, 2007 03:40 PM
