What is GK?
Old Apr 19, 2015 | 03:44 PM
kram80122's Avatar
What is GK?
I've asked several times in other forums, but haven't gotten a response. Thanks.
Old Apr 19, 2015 | 03:59 PM
exl500's Avatar
It's Honda's code that denotes the generation of Fit. The first was GD, second, GE, and the new one, GK. It has come to be used among us HondaFitistas.
Old Apr 19, 2015 | 04:32 PM
DWils's Avatar
Old Apr 19, 2015 | 05:02 PM
kram80122's Avatar
Thanks very much.
Old Apr 19, 2015 | 05:03 PM
kram80122's Avatar
Originally Posted by DWils
Searched through the list, but didn't find it there.
Old Apr 22, 2015 | 10:26 PM
Myxalplyx's Avatar
God Knows!
Old Apr 22, 2015 | 11:04 PM
TaubBaer's Avatar
Same as our other car, Hyundai: EF, NF, YF, LF. Ours is YF.
Old Sep 20, 2020 | 01:48 PM
RoyDynamicgk5's Avatar
D
Wrong thread, sorry !
Old Sep 22, 2020 | 08:44 AM
Jazu's Avatar
GK is found on the car's VIN (same for the previous models like GE). Here's an example for the GP fit
Old Oct 4, 2020 | 02:12 PM
Sorry for my wrong posting...
Old Dec 3, 2020 | 07:30 PM
MasterKwan's Avatar
This hose routing looks pretty funky. Are you running two flex sections together unsupported?
Old May 17, 2021 | 07:53 AM
Spacecoast Tardis's Avatar
Installed the Fit Sport front spoiler on my 2018 EX.
Old Jun 14, 2021 | 02:00 PM
Wht_GK5_Tx's Avatar
Those are some nice rims.
Lovin those RPF1’s. What offset are you running? Tires? And are those HFP side skirts?
Old Jun 14, 2021 | 02:22 PM
15x7 - 41mm offset. Konig Helium Center caps with Ebay Honda emblems. 10 mm spacers & longer lug studs in rear and camber bolts in front with -1 camber. 195/60-15 Firestone FireHawk AS
Old Jun 14, 2021 | 02:37 PM
Wht_GK5_Tx's Avatar
I like this. It’s similar to what I have.
Old Oct 15, 2021 | 05:17 PM
Clarencejboddicker's Avatar
Js racing titanium exhaust
sorry wrong thread
Old Sep 2, 2022 | 05:22 PM
optionz's Avatar
edit-
wrong thread sorry
Old Oct 5, 2022 | 06:12 PM
pepecarlo007@gmail.com's Avatar
Lifted Fit
Went from the default ground clearance of about 4.5 inches to 10 inches. Stiffened up the suspension springs and added bigger tires. Very happy with the end result. Been driving for a little while and nothing bad so far. Will have to wait and see if anything changes in the following months but I expect no issues. Just happy I won't have to worry about the underside scratching when I drive around bad roads in the city and in the mountains. Would post a photo but my photo uploads keep getting stuck at 90 percent.
Old Oct 6, 2022 | 04:48 PM
woof's Avatar
Originally Posted by pepecarlo007@gmail.com
Went from the default ground clearance of about 4.5 inches to 10 inches. .
That should make it a lot easier for the thieves to slide underneath there and cut out your cat.
Old Jan 25, 2023 | 09:20 AM
Superhatch's Avatar
Today I'm going to reset the low pressure indicator like I do any time there is a 5 degree temperature change.
