Function & Form Type 2 Coilovers - Rear Panel Cover & Ride Quality
Old Apr 28, 2015 | 01:39 AM
unfitforsure's Avatar
Hey guys!
I recently purchased and installed F2 Coilovers for my GE.
I have 2 concerns:
1) The rear panel cover(as shown below) won't fit back in because of the dampening knobs. Has anyone who had these coilovers have this problem?Name:  20150427_220130_zpsqfrdt5ax.jpg
Size:  176.6 KBName:  20150427_220111_zpscgzatgei.jpg
2) I have read reviews about these coilovers around the forum and it seems everyone had the same conclusion of the ride quality being alright. But I feel every bump on the road. I know it might be because I might need softer springs, play with the dampening settings a little more, or let it settle since I barely installed it about 3 days ago. It's a little annoying that its very bouncy. The car are on 14" steelies with about one finger gap. Its temporary while I order my new set of wheels (17x7 +30 or +35)
Do you guys have any suggestions? Any would help. Thanks in advance
Old Apr 29, 2015 | 11:12 AM
F..it's Avatar
I'm having the same issue with my BC Racing coilovers as well. I've managed to get it to ride better by reducing the preload on the rear spring. However I think the rear needs some more tweaking as I now have clunking at lower speeds (nothing at highways speed), and it's still a little harsh.
AC
Old Apr 29, 2015 | 02:35 PM
AC
I softened the dampers for both front and rear; it got a little better(still a little bouncy than im used to) but my front passenger dampening knob doesn't seem to get maxed out. it keeps turning and turning .
I called F2 about it and they said that its unlikely to be stripped and that I might just need to re-tighten the knob part
Old May 11, 2015 | 04:40 PM
F..it's Avatar
My issue was solved by backing off the preload on the rear springs
AC
Old Aug 3, 2015 | 08:00 PM
PaeGe8's Avatar
i have the same coil overs, ff type two's and know how you feel about the ride quality... lol its quite bouncy when going over bumps. I've messed and tried setting the preload on the rear many times and is still quite bouncy since it feels like all the bounciness is coming from the rears. so I'm planning to swap the coil springs with some swift metrics. I've heard of a slammed fit ge with the same coils.. and he said after switching to swifts.. it was a lot better. I'm planning on doing the same and will let you know about it. and it is also the same for me for the rear panel.. i gave up
Old Aug 3, 2015 | 08:43 PM
GolNat's Avatar
Stiffer sidewalled tires can help with bounciness also. With higher spring rates the tires start flexing more as they are the weakest link.
killswitch9
Nov 3, 2014 06:32 PM
duzntFIT
Dec 11, 2013 12:06 AM
RetroAttack
May 26, 2011 09:35 PM
ChrisG
63
May 8, 2011 05:04 PM
joemama4646
15
Nov 18, 2010 05:01 AM
