Skunk2 Fit Exhaust is out!
Old Oct 1, 2006 | 08:25 PM
leonine's Avatar
Just found this on their website!
60mm exhaust. $598.00
What do ya think? Too big in diameter?
Old Oct 2, 2006 | 01:32 PM
sonorliteman's Avatar
Knowing that we are starting off with this stock setup:
"So the rate of flow for the VTEC engine is now 55litres per second as compared to 50 litres per second for the i-DSI and this is achieved by increasing the diameter of the exhuast piping from 38.1mm to 42.7mm while the rear muffler volume is increased from 8 litres to 10 litres at the same time." (taken from http://asia.vtec.net/Series/FitJazz/lseries/index.html)
So a 12% increase gave 5 lps flow increase going from the 38.1 (~1.5" diam) to the 42.7 (~1.7" diam) piping....apply this percentage change ratio to a 40% increase (from 42.7 to the larger 60mm piping) it should gain ~16 liters/sec in flow, all else being equal. I'm sure there is a more accurate way to estimate this...the above is very rough. But a 40% diameter increase seems really nice, although the Fit's stock engine may not make much more power.
Unless combined w/ other bolt-ons, I don't think the power increase would be that great. I think it is a very expensive way to change the sound of your car!
Old Oct 2, 2006 | 01:33 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
they will be releasing a 50mm sized setup in the future, the 60mm would be used
along with like a turbo setup or something
Old Oct 2, 2006 | 01:35 PM
leonine's Avatar
I am also planning on intake and header so according to the folks at skunk2 the 60mm would work.
I also spoke with them on the phone today and they stated that they ran several setups and the 60mm made the most power on a stock motor.
Old Oct 2, 2006 | 01:40 PM
After looking at some generic exhaust sizing charts, the 60mm (close to 2.25") is suggested for smaller engines making ~150 hp. So it shouldn't be too big, if used w/ other mods.
leonine, did skunk indicate the gains they saw?
Old Oct 2, 2006 | 01:46 PM
leonine's Avatar
no they haven's released that info yet. Still my favorite, although i really like the angled exit on the ASPEC. S2 is for me though.
Old Oct 2, 2006 | 02:22 PM
docjim2's Avatar
wouln't be a bit cheaper to buy a "universal" muffler and have 60mm pipe bent and welded to it? Uh, that is if you want it JUST for looks and not street racing.
Old Oct 2, 2006 | 02:30 PM
leonine's Avatar
Yeah it probably would be cheaper but i'll spend the dough for a simple bolt on that i can do myself and to have a quality product. Not to mention it is stainless. That would cost $$$ even if you were gonna have a custom fab one.
Old Oct 2, 2006 | 03:02 PM
GoFits's Avatar
WOW...looks just like HKS, APEX'i, Tanabe, etc...How original of Skunk2!
Old Oct 2, 2006 | 04:23 PM
docjim2's Avatar
I found a "performance" shop that has nice stainless mufflers @ $99 and up. But some of the people that post here talk about Photoshop like it is a $46 dollar program and I know what Photoshop costs. I'm not that rich!
Old Oct 2, 2006 | 04:28 PM
leonine's Avatar
Go for it.
Old Oct 4, 2006 | 10:01 PM
yobtah's Avatar
It doesn't quite work like that. The cross-section of an exhaust pipe is a circle. We know the diameter of the circle is 42.7 mm for the OEM pipe and 60 mm for the new pipe. Area of a circle is pi * radius ^ 2. So... for the OEM pipe, the cross-sectional area is 1432 square millimeters. For the 60 mm pipe, it's 2827. That's a 97% increase in area (and volume as a result)!
The Temple of VTEC article you quoted isn't saying that the exhaust size increase resulted in the 5 liters per second flow increase. It's simply saying the 1.5 liter engine (probably the head, mainly) can flow 5 liters/second more, and the exhaust piping is larger to avoid being a restriction.
In general, increasing the size of an engine's exhaust piping won't increase the flow rate of the engine unless the exhaust is the restriction. I'm certain that the Fit's exhaust stops being the restriction way before it's 60 mm in diameter. It's really likely that the head is the restriction, and increasing exhaust size (especially that much) has very little, if any, effect.
Old Oct 4, 2006 | 10:18 PM
Good points...I wasn't saying it would increase engine flow itself, but was alluding to increase capacity of the exhaust. I guess the sentence can be misleading, as I read it to mean: "So the rate of flow...is now 55litres per second...and this is achieved by increasing the diameter of the exhuast piping from 38.1mm to 42.7mm while the rear muffler volume is increased from 8 litres to 10 litres at the same time".
But you're correct about the volume increase being significant. I just wonder what a 97% increase does to the exhaust gas velocity...and if this really matters once exhaust passes the cat.
Old Oct 5, 2006 | 07:40 AM
yobtah's Avatar
The bigger diameter exhaust piping will definitely slow exhaust flow... but I don't know how much.
I have a couple of guesses on why Skunk2 would use 60 mm piping:
      Either way, I'm guessing they didn't do it purely for performance. Without some major head work or forced induction, the L15 isn't large enough and doesn't flow enough.
      Old Oct 5, 2006 | 08:26 AM
      carlosalicea's Avatar
      • It's what they had on hand, and it would have been more difficult to get smaller piping.
      • They're worried people who are accustomed to 2.25" or 2.5" piping on Civics and Integras would see smaller than 2" piping on a $500 aftermarket exhaust and think it's not worth the price.
      I totaly agree....
      Old Oct 5, 2006 | 01:32 PM
      dacalac's Avatar
      If you guys really want this post to be effective. I can merge it with the existing one IN THE SKUNK2 VENDOR FORUM.
      JDMchris.com
      49
      Nov 6, 2009 07:33 PM
      smeister
      Jul 16, 2008 10:08 AM
      its.ryu
      29
      Dec 11, 2007 11:06 AM
      daviddahlb
      Apr 18, 2007 10:39 PM
