I have audio questions I rarely need but online answers have stumped me even more.
Old May 30, 2015 | 07:11 PM
Desmond Lamar MacRae's Avatar
Question I have audio questions I rarely need but online answers have stumped me even more.
Ok I hope you guys knowledgeable in car amps/set-ups can school/explain a feature on a JL amp that I never saw before and if I should even use at all.
Ok here is my set-up i just finished my pre-install. If pix come out to big i apologize.
Mids/Highs (front and rear) why? i got a deal (299.99msrp/i got for (170/pr) i couldnt pass up
Product Highlights:
component speaker system includes 2 woofers, 2 tweeters, and 2 crossovers
6-3/4" Plus One+ glass-fiber woofer with hi-roll rubber surround
adapter rings included for 6-1/2" openings
3/4" edge-driven soft dome tweeter
Starfish™ mounting brackets for easier tweeter installation in factory locations
2-way external crossover network
2-ohm impedance
tweeter adjustment circuits (0, +3 dB)
power range: 5-90 watts RMS (270 watts peak power)
frequency response: 45-35,000 Hz
sensitivity: 93 dB
woofer top-mount depth: 2-1/8"
warranty: 3 years
(mids/highs) Amp JL 300/4 v2 (was given to me from a good friend) MSRP was 559.99 new.
Power: 75watts x 4 @2 ohm
Sub:
Alpine Type E 10" (lower line alpine but all i was looking for was an 8. I was gifted this as well)
Stats:
Features and Specification
SPECIFICATIONS
Power Handling
Power Range: 100W-250 Watts
RMS Power Handling: 250 Watts
Peak Power Handling: 750 Watts
Dimensions
Mounting Depth: 135 mm (5.3'')
Mounting Diameter: 228 mm (9'')
Displacement: 0.055 cu. ft. (Front Mount)
Added Volume: 0.061 cu. ft. (Reverse Mount, Magnet Out)
Sub amp:
Coustic 320QE (I bet youre like "who". I did too. I was told it was a side line of MTX_
Stats:
- Triple Darlington Drive Circuitry
- Adjustable Bass Boost
- Built-in HPF / LPF with Continuously Adjustable Crossover Frequencies
- Remote Subwoofer Level Control Ready
- Switched RCA input
Rated Power @ 14.4 V (0.1 % THD) 4 Ohm Stereo: 4 x 40 Watts
Rated Power @ 14.4 V (0.1 % THD) 2 Ohm Stereo: 4 x 80 Watts
Rated Power @ 14.4 V (0.2 % THD) 4 Ohm Mono: 2 x 160 Watts
Input Sensitivity: 0.1 - 5 V
S/N Ratio @ rated power: 100 dB
High-Pass Filter Crossover Frequency: 30 - 300 Hz (Continuously Variable, @ 18 dB/Oct.)
Low-Pass Filter Crossover Frequency: 30 - 300 Hz (Continuously Variable, @ 18 dB/Oct.)
Bass Boost Level: 0 - 18 dB @ 45 Hz
Now here is my question on a feature on the Alpine app that ive never seen and what to even do with it. Thanks to my fit brothers/sister in advance.
Here is the JL amp from the side.
Heres my question. What is slope (Slope 12db/24db) for and when would/should I use it and which slope would u recommend for me set-up?
Again thank you for all of your opinions and direction.
Old May 31, 2015 | 10:23 PM
DrewE's Avatar
The filter slope is how sharply the high pass/low pass filter cuts off. I believe you'd probably use the high pass mode, setting the frequency for your subwoofer/main driver crossover point. The 24 dB/octave cuts off more sharply than the 12 dB/octave setting.
If you're using some other crossover for the subwoofer, you presumably don't need the filter at all and so the slope is immaterial.
Old May 31, 2015 | 11:25 PM
Thank u. yes most ive read did 12. My sub amp has no slope control. so dont use the slope at all?
TequilaSqueela
Jun 18, 2015 06:01 PM
setter11
Sep 29, 2009 10:55 PM
sethne
Jun 27, 2009 03:43 PM
BDR
Jan 22, 2009 12:36 AM
revzero
Sep 12, 2007 09:57 PM
