Overcharging battery
Old Jun 13, 2015 | 09:46 PM
mexfreak's Avatar
Question Overcharging battery
Hi, I had a new battery installed by Honda agency (Mexico) approx 3 years ago and all has been good until now. I had always thought it was maintenance free but it went flat recently after leaving the car unused for several days and I noticed the two filler caps. Of course the plates were dry - I topped the levels up with de-mineralized water and jump started the car. It now starts OK but the voltage at idle is around 19 volts. Is this just because the battery is still pretty flat or is it a regulation problem?
Old Jun 14, 2015 | 05:18 AM
n9cv's Avatar
19 volts is definitely a problem. Battery charging is usually done at 13.8 to 14.2 volts with a little higher in very cold conditions.
Old Jun 14, 2015 | 10:16 AM
Carbuff2's Avatar
Furthermore, that 19V could be why the battery fluid 'boiled' out.
So get it checked out. (probably an alternator problem)
BTW, FWIW, Honda charging systems normally run at ~ 14 .5 VDC - 14.7 VDC.
pzriddle
Jan 23, 2015 06:31 PM
N.O.R.M
Mar 31, 2013 12:23 AM
MTLian
Jan 15, 2013 02:32 PM
ccaleb02
Nov 29, 2008 09:56 AM
Remco
May 4, 2005 11:16 AM
