Fit Sport 2012 (25,000) - Service @ Honda Dealer
Old Jul 22, 2015 | 05:12 PM
JanFit's Avatar
Cool Fit Sport 2012 (25,000) - Service @ Honda Dealer
Hi,
i went to Anderson Honda, Palo Alto today.
The service advisor mentioned that i need to to do Maintenance B ($182.90) which is
  1. Replace Engine Oil (Synthetic)
  2. Replace Engine Oil Filter
  3. Check front and rear brakes
  4. Includes tire rotation
  5. Includes multi point inspection
  6. Check parking brake adjustment
  7. Inspect brake hoses and lines
  8. Inspect driveshaft boots
  9. Inspect exhaust system
  10. Inspect fuel lines and connections
  11. Inspect front and rear brakes
  12. Inspect suspension components
  13. Inspect tie-rod ends, steering gearbox, and gear box boots
  14. Inspect all fluid levels and conditions of fluids
Replace air cleaner element Replace dust and pollen filter Inspect drive belt which is ($137.00)
and Brake System Flush ($130.00)
I told him i dont want the brake system but he highly recommended it since it is 3 years old.
Now i found that most of these can be done like $150 in total. Did i just get fooled? What is your recommendation next time?
Old Jul 22, 2015 | 05:53 PM
xxryu139xx's Avatar
my Honda dealer runs a special for 19.99 and u get pretty much an oil change and filter and multipoint inspection free. i rotate the tires myself. air filters are cheap to diy. brakes sure maybe. but people here recommend 60k. i'm surprised they didnt suggest transmission flush at 30k since most people recommend that.
Old Jul 23, 2015 | 10:40 AM
Uncle Gary's Avatar
I change my own oil and filters and rotate my own tires. That way I get to choose what oil I use, not what the dealer got the best price on that month. I also change my own air cleaner and cabin air filter. Beyond that, there's not much to do on a modern car except, as you list there, "inspect" the various fluids and systems. Then again, there's not a lot more than this I know how to do on cars anymore. Especially since I can't get a hard copy of the shop manual anymore.
Yes, Honda recommends brake fluid changed at 3 year intervals. My dealer's service department checked mine yearly with a "test strip" that showed moisture level in the fluid, and told me I was "good" until 5 years, when I had I finally had it done.
The real "rip off" here is replacing the cabin air filter and air cleaner. You can buy them both on line for about $40 and install them yourself in under 5 minutes.
If I have the car into the dealer for any reason, they include the "multi-point" inspection for "free". And why not? It's a good way to drum up more business.
Old Jul 24, 2015 | 02:38 PM
domoMKIV's Avatar
Unfortunately, you spent a whole lotta money for not a lot of work.
$182 for a $35 oil change and tire rotation.
$137 to change 2 very easily accessible filters that would cost about $40.
Brake flush, meh.
Old Jul 24, 2015 | 03:21 PM
Fit Charlie's Avatar
I just spent $20 on a filter and 4 quarts of 0w20.
Old Nov 23, 2015 | 10:55 PM
prhkgh's Avatar
I tow a 1000# trailer with my 2012 base AT fit. So whenever my oil life gets down to about 40% I change oil and filter (mobil one 0-20), and also drain out what I can from the AT, which is 3.5 to 4 qts. I use Honda AT fluid which is usually around $7 a qt on sale. (The transmission holds much more...but changing the 25% I can drain without a flush at each engine oil change is about the same as a flush and fill at 60,000. I rotate or have tires rotated between 7000+10000 miles. Simple. And since I am towing, at 50,000 miles when stock front pads were getting thin, I put in EBC semi-metallic autocross pads. Best swap I've done on the car, never liked the feel of the ceramics.
Old Nov 30, 2015 | 12:42 PM
my '12 is coming up 25k pretty soon. I only plan to do the oil and oil filter change.
The rest is visual inspection. I will not be doing the brake fluid change either.
Old Nov 30, 2015 | 02:58 PM
dwtaylorpdx's Avatar
You can always suck the fluid out of the brake resevouir and replace. That way your ABS unit gets nice fresh fluid when it cycles. And its cheap to do yourself. 10 bucks and a turkey baster or mighty vac.
Pucci
Oct 28, 2015 01:55 PM
zukered
Dec 10, 2013 07:19 PM
D50boy
May 4, 2011 02:50 PM
AJR Jay
Jan 5, 2011 06:57 PM
footloose
Jul 4, 2009 09:51 AM
