Wider tires with stock wheels?
Old Jul 22, 2015 | 07:25 PM
andre181's Avatar
Can I run a wider tire on the stock wheels? Maybe like a 205/45?
I really like the stock wheels but I feel like the narrow tires compromise the ride a little.
Old Jul 28, 2015 | 11:02 AM
bigbacon's Avatar
i was looking at something similar as well. My suspicion is you could definitely bump up to says a 195 which looks to open up a world of better tire choices over 185s. I've done that on our old mini bumping up from 195 to 205 without issue.
Old Jul 29, 2015 | 02:59 AM
DaBinChe's Avatar
stock width is 6" so a 195 for sure and I think a 205 would be okay as well. 185 is actually as wide as you'll want to go with the stock 6"
Old Jul 29, 2015 | 07:50 AM
bigbacon's Avatar
this doesn't really make sense...
you say 195 is ok on a 6" yet then you say 185 is as wide as you'll want to go on a 6"
Old Jul 29, 2015 | 10:32 AM
DaBinChe's Avatar
I meant that 185 is as narrow as you can go with the 6" rim
Old Sep 29, 2015 | 08:01 PM
rodney's Avatar
just purchased a set of falken pro g4's for the stock wheels. i went up in width, to the high end of what the rim can handle, 205/50-16. will have them mounted in a few days.
i did the same thing on my previous commuter, and it worked out very well. expecting the same results with the fit.
Old Sep 29, 2015 | 08:45 PM
GolNat's Avatar
^205/50 is good as it is close to stock rolling diameter. Nice looking tires.
Depends on the tire. Look at the tire spec to determine the range of rim width that a particular size will work with. Some tires may be able to go up to 205 on a 6" rim while others can not.
demouser
Mar 23, 2021 08:46 AM
B Fit
Jan 15, 2013 01:36 PM
FitVic
Jan 13, 2010 05:10 PM
sterVin
Jun 17, 2008 07:26 AM
squareback
Aug 3, 2007 07:06 PM
