2005 honda fit, keyles starting.
Old Sep 21, 2015 | 01:55 PM
Empiexxxx's Avatar
I have a 2005 honda fit with the climate control and cvt transmission. And the part where the key goes in is like a plastic thing that allows the key to be inserted.. but that plastic thing can also be covered up. And on the cover it says push/turn to start. Which would only mean that i can start the car without the key.. but i cant with the only key i got. It is a single button remote key, which needs to be inserted then pushed and turned to start the car.
I'm wondering how to get my cat to start without a key
Old Oct 7, 2015 | 06:10 PM
Belch's Avatar
You need something called a "smart card" that's slightly larger than a credit card. With that, you don't need to use a key.
I have one for mine, but it's a hit or miss thing for auto locking. The idea is you just walk away and it will lock itself. It certainly will 9 times out of 10, and if it doesn't, it will make a BEEP BEEP noise letting you know it didn't work. Rather embarrassing.
Press Fit
Mar 3, 2023 09:59 PM
Jensen Healy
Mar 17, 2017 02:38 PM
Cassini
Jan 6, 2013 10:57 AM
jelliotlevy
Feb 11, 2009 08:12 AM
yeamans17
Dec 13, 2007 11:25 AM
