Odd cell phone issue...
Old Sep 28, 2015 | 02:33 PM
2Rismo2's Avatar
So I just got a Moto X Pure (Android) and I've connected it through bluetooth to the Fit. When I get a text it notifies me. The weird thing is, when I send a text it notifies me that I got a text too. It says there is a text from my number immediately when I press send on the text message app. If I change it to not notify me when I receive a text, obviously it doesn't notify me when I send or receive a text.
On my previous cell phone Galaxy SII Skyrocket it worked as it should. Get a text, it notifies me. Send a text, no notification.
I've already removed the bluetooth connection on both the Honda and the phone and rebooted. Then reconnected and it behaves the same. The phone is running Android 5.1.1 and I'm using the built in Messenger app. I tried using the Hangouts app and merging SMS there, and it's the same behavior.
Everything else works. I can stream music through Pandora or Amazon Prime and I can make phone calls. Any insight would be appreciated.
Old Sep 30, 2015 | 01:38 PM
2Rismo2's Avatar
Bump, anyone?
I'm going to try the wife's Galaxy S4 to see if it does it too. I hadn't thought to try that.
Old Sep 30, 2015 | 02:09 PM
Bassguitarist1985's Avatar
I too have experienced this issue. I believe it is a flaw in the firmware code of the HU. This behavior is especially true with a chain text message with multiple recipients. If you are in the middle of writing a text but don't send immediately, the HU alerts you you got a text message from yourself, you click read and says it cannot retrieve the message.
the work around is to disable the head up prompt you have text messages and simply check the inbox of your txts via the HU manually, which can be done while driving. It will read them back as it normally would.
Old Sep 30, 2015 | 02:14 PM
2Rismo2's Avatar
OK, I'm glad I'm not the only one. Are you running an Android too, and if so what OS version. Just trying to see if there is a pattern.
Old Sep 30, 2015 | 02:49 PM
Im running Samsung Galaxy Note 4 on Android 5.0.1
Old Sep 30, 2015 | 02:51 PM
2Rismo2's Avatar
OK, my Galaxy S2 Skyrocket running Android 4.1.2 didn't have this issue as a comparison.
Old Sep 30, 2015 | 02:56 PM
Hmm interesting. So something is effed with Android 5 then?
Old Sep 30, 2015 | 09:04 PM
2Rismo2's Avatar
I borrowed my wife's galaxy s4 running 5.0.1 and it works fine. She's using the stock messaging app as well. I added the phone just like mine to the honda and I tried to compare settings but nothing jumped out as different. I turned off her Bluetooth and reconnected mine and it stops working as it should. I turn off mine and reconnect hers and back to working. Something screwy going on.
When hers connects to Bluetooth, it plays a musical tone. Mine does not.
Old Oct 8, 2015 | 07:52 PM
kc750's Avatar
Same issue for me on LG G3
My LG G3 with Lollipop 5.0.1 does the same thing. I am not impressed with the head unit in my EX and I'm not confident that it will be resolved any time soon (cue the Honda crickets).
silverfitted
Mar 28, 2019 05:15 PM
Nero27
Sep 12, 2018 09:29 AM
puffysweater
Apr 30, 2017 09:31 PM
richtpt
Feb 17, 2015 03:46 PM
BarrieFit
Jan 2, 2015 07:09 PM
