OEM Front Lip Removal DIY? for GD3 Fit
Old Oct 1, 2015 | 04:58 AM
RandomKoko's Avatar
How do you remove the OEM front lip?
I removed the bumper but there are clips connected to the lip. I'm not sure how to remove them, also reinstalling.
I'm planning to buy a new one due to the old lip bend and minor crack.
Please help thanks.
Old Oct 1, 2015 | 06:44 AM
DWils's Avatar
If there are clips attached to the lip can't you just remove the clips to pull the lip off?
Old Oct 1, 2015 | 09:02 AM
Carbuff2's Avatar
The front lip (or 'spoiler' in Honda parts lists) can be removed without removing the bumper. It is anchored by the visible bolts in each wheel well, and bolt-on metal brackets along the front. You need to remove the plastic splash shields under the front to unbolt the brackets. (Which could have been bent if the spoiler was scraped on a curb or something.)
Our spoiler was split due to curb damage. Rather than replace it I re-attached the pieces using hot glue and a rectangle of synthetic wood for reinforcement.
Before
After hot glue, positioning reinforcement block
Insider's View
It's been holding up fine for three years, now.
CamperCarl
Jun 24, 2019 11:06 AM
Fitguy07
May 17, 2011 12:52 PM
xonexlifex
Mar 25, 2010 06:33 PM
iheartmyGD3
May 11, 2007 02:21 PM
POPiPOP
Oct 24, 2006 02:26 AM
