Cylinder head gasket
Old Nov 30, 2015 | 05:22 PM
nvsquared's Avatar
Can anyone tell me if a Cylinder head gasket for a US 2007 Honda Fit will fit in the engine of a 2001 Honda Fit From Japan? From all my research it seems that they have the same engine so the parts should be interchangeable but the part numbers are slightly different. 12251-PWA-J01 for the Japan and 12251-PWC-J01 for the US. Please let me know.
Old Nov 30, 2015 | 07:43 PM
dwtaylorpdx's Avatar
Most of the manufacturers have a hotline you can call for tech help, TRW or others, you might be able to get help there,, most likely its the thickness of the gasket, is the JDM engine higher or lower compression.. ??
Old Dec 1, 2015 | 05:29 AM
Charly's Avatar
Different codes are for different caratteristics so I would avoid.
Old Dec 1, 2015 | 11:31 AM
nvsquared's Avatar
From my research, it seems that the JDM engine is slightly higher in compression. 10.8:1 as opposed to 10.4:1 in the US model.
Old Dec 2, 2015 | 06:40 AM
DWils's Avatar
If you Google the part numbers you can get pictures of them. They look a little different.
Old Dec 2, 2015 | 07:30 AM
nvsquared's Avatar
Thanks everyone....it seems that they are indeed a bit different.
mnapuran
Jan 27, 2019 07:46 AM
pritchandpurds
Oct 27, 2012 12:59 PM
CelestialBlue
Aug 13, 2012 12:30 PM
CelestialBlue
Aug 10, 2012 04:16 PM
Gerry
May 4, 2005 11:16 AM
