Rear suspension axle mount bushings
Old Dec 16, 2015 | 08:56 AM
Foiled's Avatar
The rear suspension axle mount bushings are both damaged and need to be replaced. This accounts for the side to side movement I've been experiencing!
Thinking about replacing it myself. Anybody have any experience with replacement of these bushings?
Old Dec 16, 2015 | 10:44 AM
Carbuff2's Avatar
Look them up first and see if they are available separately, or only as part of the axle...
Check both Honda online dealers and aftermarket.
I looked at Rock Auto quickly and I only see only front suspension components.
Old Dec 16, 2015 | 01:02 PM
Foiled's Avatar
Old Dec 23, 2015 | 08:07 PM
vap3's Avatar
that's pretty cheap! i wonder if the diy is easy too... i assume you need a pair of these?
Old Dec 24, 2015 | 08:56 AM
Foiled's Avatar
I do not know how hard this would be. The main thing I see is a person would need to remove the gas tank filler tube since it is routed below the axle. I am goint to get an alignment shop to look at the bushings on mine to see if they need to be replaced.
Old Dec 28, 2015 | 12:54 PM
Rollerboots666's Avatar
The bushings are going to have to be pushed out and back in. This is not an easy task. Depending of the damage you have the bushing could just be filled with window weld and work. That's an easy fix and less stressful.
jfw432
Sep 10, 2013 10:21 AM
vaah
Sep 7, 2013 05:27 AM
apexanimal
Feb 4, 2013 12:23 PM
kurisux92
Aug 11, 2011 12:33 PM
quangalang
24
Aug 1, 2007 05:43 PM
