Idle drops and car seems like wants to turn off
Old Jan 15, 2016 | 05:39 PM
noelrobles22@gmail.com's Avatar
NEED HELP PLEASE. Coil packs
I tried to remove the coil packs and 2 came apart leaving half in still how can I remove it any info please.. just got this fit and been having issues.
Old Jan 15, 2016 | 06:00 PM
Wow 16 views and not 1 person with any kind of tips?
Old Jan 15, 2016 | 06:27 PM
Thanks everyone
Old Jan 16, 2016 | 10:59 PM
fit2bking's Avatar
stick some needle nose pliers down there and pull it out!
Old Jan 16, 2016 | 11:03 PM
Haha Thanks that's what I did
Old Jan 17, 2016 | 05:35 PM
https://www.dropbox.com/s/ix1pk4ox7i...64029.mp4?dl=0
Ok so I bought a fit last wk and been trying to figure out some issues. A cel came on the day after I got it and said misfire in cylinder 3. I spoke with the previous owner he said he changed the coil packs and spark plugs but I found out he only changed 2 spark plugs and 1 coil pack. From researching I decided to change all 4 coil packs and spark plugs. Car seems to drive good but now the issue is when in park the idle seems low and if I Rev it up and let it come back down it will go to 0 and feel like it wants to turn off. Any ideas please help I'm new to the fits and not what I expected to deal with a wk of having her. I made a video but no idea how to post it on here..
Old Jan 17, 2016 | 06:27 PM
Carbuff2's Avatar
Post your vid on Youtube, or load it to a file sharing site like Dropbox or Photobucket.
I'd Clean the Throttle Body and do the Idle Learn Procedure. If that doesn't solve the issue, have the valve lash adjusted.
Let us know how you made out.
Old Jan 17, 2016 | 06:30 PM
What is the idle learn procedure?
Old Jan 17, 2016 | 06:39 PM
Carbuff2's Avatar
SEARCH the term on this Forum.
Basically, you idle a warm engine for 5 minutes (with the a/c, cooling fans, and other electrical loads OFF). The engine computer will then learn the proper idle RPM. (It will eventually learn it on it's own, too...but the ILP is faster)
Do this AFTER you clean the throttle body... (You can SEARCH that procedure also)
Old Jan 17, 2016 | 06:41 PM
Ok cool thanks for the info I will try to clean the throttle and do the idle procedure
Old Jan 17, 2016 | 06:50 PM
I put the video on Dropbox and added the link. If you want to check it out
Old Jan 17, 2016 | 08:06 PM
Perrenoud Fit's Avatar
The GD3 is a great car but have their share of quirks. Don't give up!
I just bought a second one and holy .... the previous owner was a cobb artist from cobitup,usa.
but all in all it's weeded out and running tight! with 184K on the clock. love it > good investment
Old Jan 17, 2016 | 08:14 PM
Thanks man, trying not to give up lol.. I changed the 4 coil packs and spark plugs seems to be running better and has mileage seems better but now there's like a whining sound when I first turn on the car and once it warms up seems to go away. Also a idle issue, it's idling low and if I Rev it up it drops to 0 and wants to shut off..
Old Jan 17, 2016 | 09:26 PM
xxryu139xx's Avatar
merged your threads together. seems like its from the same problem.
Old Nov 20, 2017 | 11:26 PM
Bulilit21's Avatar
Same experience. Low idle, jerky low rpm acceleration. Found out that i have oil in my plugs thread. Is it possible this is the reason why?
MSILVEST04
Jan 25, 2022 08:56 PM
wackyflik
Sep 22, 2014 09:39 AM
codenamezero
Mar 2, 2014 04:00 PM
Harriswt
Mar 19, 2013 01:56 PM
Koi
Feb 24, 2010 01:28 AM
