Spark plug hole..
Old Jan 20, 2016 | 06:19 PM
noelrobles22@gmail.com's Avatar
Spark plug hole..
Not sure what/if there's a exact name for where the spark plug goes in.. well wondering what could cause it to get dirty? I was changing the coil packs and spark plugs and noticed sparkplug hole #3 counting from left to right was the only hole dirty as shown in pic. Any ideas or info?
This is the dirty hole from spark plug #3
Compared to this hole. 3 out of 4 holes look like this pic.
Attached Thumbnails Spark plug hole..-80-20160120_170210_1b643e0edbc2d65d60946b9c8f6c219212183794.jpg   Spark plug hole..-80-20160116_052610_d618b03579c9142692e522af25be3b6860228fd8.jpg
Old Jan 21, 2016 | 05:01 AM
gallent92's Avatar
That's some good accumulation of residue, no idea though but curious to know where they came from.
Old Jan 21, 2016 | 05:25 AM
Yes h I'm curious to know what can cause that. I can tell you I added 4 new coils and spark plugs with recommended brand and I still had cylinder 3 misfire along with a odd whining noise that started happening after is changed out the coils and plugs... so yesterday what I did try to clean the whole alittle and I put a different coil in it and s=emed to drive better then it has since I got the fit 2 wks ago. Cel usually pops back on with in a day so we will see how it goes...
Old Jan 21, 2016 | 08:13 AM
ezone's Avatar
The buildup appears to be carbon, which would typically be the result of a spark plug that was not tight enough to seal properly.
Old Jan 21, 2016 | 09:00 AM
Thanks for the response I will double check the spark plug
Totman
Jan 22, 2025 11:47 PM
VelvetB
May 11, 2016 06:59 PM
Rollerboots666
21
Mar 2, 2015 07:46 PM
wackyflik
Oct 4, 2014 09:11 AM
lukeskywalker1
Feb 23, 2014 05:42 AM
