Electrical on a horn replacement
Old May 22, 2016 | 04:14 PM
msoulier's Avatar
Hi,
I have a 2010 and I was just looking at my horn, and about to replace it with a generic Framm replacement when I realized that I don't really understand the electrical hook-up. I see one wire going into a small box attached to the horn, when I was expecting a one or two lead connection where I could simply unhook the old and plug in the new.
Can someone enlighten me on this hook-up?
Thanks,
Mike
Old May 22, 2016 | 04:33 PM
DrewE's Avatar
I think what you're calling a "small box" is just the electrical connector for the power line to the horn. It's grounded through its mount.
Old May 22, 2016 | 05:46 PM
msoulier's Avatar
So, to disconnect it do I just pull on it? It seemed rather firmly attached.
If it's grounded through the mount then it qualifies as a "single line" interface in the manual on the replacement horn. That should work fine.
Old May 22, 2016 | 10:46 PM
DrewE's Avatar
There's probably a clip holding it together somewhere that you need to squeeze or gently pry apart (probably squeeze). It's hard for me to tell precisely as I don't really feel like disassembling the front decorative grill for no good reason. Even with the latch disengaged, sometimes some electrical connectors can be a bit of a hassle to get apart.
Old May 23, 2016 | 05:11 PM
Satchel's Avatar
There is a clip you press down on to remove the plug. I swapped my horn for the Accord horn a few weeks ago...best $15 I've spent in a while.
HaulSmall
Mar 31, 2011 06:33 AM
AndrewLOL
Jan 29, 2011 10:37 AM
The Assassin
Aug 22, 2010 09:52 PM
CMegalodon
Mar 12, 2009 02:04 AM
duckbill
Jul 5, 2005 07:44 AM
