TPMS wheel sensor question
Old Jun 26, 2016 | 09:31 PM
tvmax's Avatar
I found a wheel sensor that says "Clone-able; No programming required. Install Sensor and follow the OEM factory relearn procedure"
Is this true? How do I perform this factory relearn procedure?
Thank you
Old Jun 26, 2016 | 10:19 PM
ezone's Avatar
In order to use a cloneable sensor, you first have to know the unique ID# of the sensor you intend to replace and have that ID# programmed into the new cloneable sensor.
The car does not have the capability to learn new sensor IDs without help (scantool and/or special TPMS tools).
Cloning sensor(s) simply duplicates the ID#(s) already stored in the TPMS control unit so you don't have to program anew.
Old Jul 1, 2016 | 09:02 AM
dlivry7's Avatar
for those of us with a separate set of rims and tires for winter, tpms is annoying. i had put electrical tape over the dash light during the winter because the honda dealership wanted a small fortune ($68 each time) to reprogram the tpms each spring and fall.
talked to the local costco auto center about it and they do it for free now. takes about 15 seconds. try a local costco if you are a member
StinklePink
Jun 30, 2014 06:34 PM
screwdriversm
Jul 21, 2013 01:38 AM
Vacca Rabite
Mar 25, 2011 11:35 AM
BraytonAK
Apr 9, 2010 11:17 AM
hondafitblue
Mar 10, 2010 07:49 PM
